lcc014 Posted July 6, 2013 Report Share Posted July 6, 2013 This no start situation has been existing for a while. No all the times, mainly happened after a long drive and stopped for a short time, about 15 minutes. Battery is in good condition - 12V measured at terminals when car is off. All I heard was a "click" sound, when turned key to II position. After that, car was quiet, starter not turning at all. All comment or diagnostic is appreciated. Ching-Ho Cheng Link to comment Share on other sites More sharing options...
Kevin. Posted July 6, 2013 Report Share Posted July 6, 2013 Starter. Maybe ignition switch Link to comment Share on other sites More sharing options...
rcstdad Posted July 6, 2013 Report Share Posted July 6, 2013 Same thing used to happen to mine when the pnp switch was giving me grief. Link to comment Share on other sites More sharing options...
jdlc Posted July 6, 2013 Report Share Posted July 6, 2013 Starter Link to comment Share on other sites More sharing options...
BlackBrick Posted July 7, 2013 Report Share Posted July 7, 2013 pretty common for ignition switch to go, happened to me. Next time it doesn't start, jiggle the key in the ignition switch and if that helps, ignition switch is your culprit. Pretty cheap and easy fix. Link to comment Share on other sites More sharing options...
Keaton85 Posted July 7, 2013 Report Share Posted July 7, 2013 You say 12v at the battery? That means nothing as 12v is a dead battery. What is that actual voltage at the battery? Link to comment Share on other sites More sharing options...
bob850 Posted July 8, 2013 Report Share Posted July 8, 2013 Mine did this exactly when the pnp was going out. I had no reverse lights also which pointed to the pnp. Link to comment Share on other sites More sharing options...
lcc014 Posted July 8, 2013 Author Report Share Posted July 8, 2013 You say 12v at the battery? That means nothing as 12v is a dead battery. What is that actual voltage at the battery? Battery voltage with engine off - 12.6V. Mine did this exactly when the pnp was going out. I had no reverse lights also which pointed to the pnp. Same thing used to happen to mine when the pnp switch was giving me grief. So far, car starts fine. I will try the ratchet method on the shifter. Backup light is working fine so far. pretty common for ignition switch to go, happened to me. Next time it doesn't start, jiggle the key in the ignition switch and if that helps, ignition switch is your culprit. Pretty cheap and easy fix. Will try this method when it happens again. Link to comment Share on other sites More sharing options...
