Brad850 Posted July 26, 2013 Report Share Posted July 26, 2013 My brother just put my 15g in his 91 740 turbo. He made a post on turbobricks a week ago with no suggestions. Wondering if maybe some of you guys might be able to help. Here's his post. Just finished putting a 15g into my 1991 740 turbo. Here is my current setup: Mikes Chips EZK/ECU 15g turbo freshly rebuilt 3" downpipe/2.5" cat back Browntops stock AMM(016?) ebay intercooler MBC set at 10psi (goal is ~16psi) stock fuel rail/pumps stock camshaft -Vacuum is anywhere between 16-18 when idle. 20 while coasting in drive.-Just replaced 02 sensor-fixed a couple of leaks in intercooler pipingAs soon as i get into about 5 psi of boost AFR's peg at 10.0...Any suggestions??? I was running lean(A/F 18.0) when under boost with an 012AMM so I put the stock AMM back in. Now under boost my car feels like crap. It is super slow and stumbling and the wideband is reading 10. I have checked for vacuum leaks and am pulling 18inhg at idle. Any suggestions as to whats causing the car to run so rich? I doubt its the browntops as they were installed previously and ran well with the 13c. The ecu was reset but have only driven a few miles. Link to comment Share on other sites More sharing options...
okoye Posted July 29, 2013 Report Share Posted July 29, 2013 How long has he driven the car? The ecu should adapt to the changes so drive it a while more. I assume you're using LH 2.4? Link to comment Share on other sites More sharing options...
James A Sousa Posted August 2, 2013 Report Share Posted August 2, 2013 Check your air cleaner. maybe the sound deadening foam has fallen apart and has clogged the filter like my '90 744 TI did. Link to comment Share on other sites More sharing options...
Brad850 Posted August 5, 2013 Author Report Share Posted August 5, 2013 How long has he driven the car? The ecu should adapt to the changes so drive it a while more. I assume you're using LH 2.4? About a half tank of gas. Here is his updated thread. You can see in his videos how crappy idle is. Really has no idea what to do. http://forums.turbobricks.com/showthread.php?t=282794 Yes to lh 2.4 Check your air cleaner. maybe the sound deadening foam has fallen apart and has clogged the filter like my '90 744 TI did. Forgot to mention he has a new clean cone filter. Link to comment Share on other sites More sharing options...
