Trunks850R Posted November 17, 2013 Report Share Posted November 17, 2013 So I lowered my S70 and can't decide which wheels I want to run on it. Ive noticed the wheels sit REALLY close to the strut. Who else has this problem? I haven't heard any rubbing, but right now I have Atlantis wheels on one side and pegs on the other and they're both a tight fit. Do I HAVE to run spacers? Link to comment Share on other sites More sharing options...
_HighVoltage_ Posted November 17, 2013 Report Share Posted November 17, 2013 Even with 17 inch pegs the wheel is dangerously close to the strut - last time Discount Tire installed a clip on wheel wight on one of the fronts and it was rubbing against the strut. I had to the take it back to get stick on weights. It's THAT close! Link to comment Share on other sites More sharing options...
andyb5 Posted November 18, 2013 Report Share Posted November 18, 2013 Well since all Pegs are 8" wide, diameter doesn't really make a difference :lol: Link to comment Share on other sites More sharing options...
kalvin Posted November 18, 2013 Report Share Posted November 18, 2013 As long as there are more than a few millimeters of space between the wheel and the strut tube you should be fine. The only way they will contact is if your shock or wheel is flexing dramatically to do so. If that is the case then I think you may have some bigger problems. Link to comment Share on other sites More sharing options...
Trunks850R Posted November 18, 2013 Author Report Share Posted November 18, 2013 Well since all Pegs are 8" wide, diameter doesn't really make a difference Oh what would we do without the peanut gallery?? I don't remember asking anything about rim diameters, and obviously my concern is with the width of the wheel. Thats why I pointed out that I have Atlantis wheels on the other side. Do they even make Atlantis wheels in anything other then 18s? Guess ill get the other 2 pegs on tonight! Link to comment Share on other sites More sharing options...
andyb5 Posted November 18, 2013 Report Share Posted November 18, 2013 That was in reply to HighVoltage's comment about clearance with 17" Pegs being close to the strut But here's some advice from the Peanut Gallery you'll find useful: Atlantis were only 18x7, et+49. OE pegs are 8" wide, and et+43. This means that the Pegs will sit ~7mm closer to the strut than the Atlantis will. If your Pegs are IPD reps, they are 8" wide and et+38. This means that they will sit ~2mm closer to the strut than the Atlantis do. Oh, and lowering your car has nothing to do with a wheel clearing the strut body or not. Idiot. Link to comment Share on other sites More sharing options...
Dick Dastardly Posted November 18, 2013 Report Share Posted November 18, 2013 the only thing more sensitive around here than dick size is wheel measurements.. Link to comment Share on other sites More sharing options...
kalvin Posted November 18, 2013 Report Share Posted November 18, 2013 That escalated quickly. Link to comment Share on other sites More sharing options...
nari Posted November 19, 2013 Report Share Posted November 19, 2013 oem 18" pegs on D2 No problems aside from the lame turning radius. Link to comment Share on other sites More sharing options...
D s50r Posted November 19, 2013 Report Share Posted November 19, 2013 oem 18" pegs on D2 No problems aside from the lame turning radius. you must have the jet tuning chip that changes the wheel spacing aswell Link to comment Share on other sites More sharing options...
sacrifice Posted November 20, 2013 Report Share Posted November 20, 2013 If the wheel/tire sits closer than an inch to the strut assembly it can definitely be deemed unsafe for use on public roadways. Link to comment Share on other sites More sharing options...
WayAway Posted November 20, 2013 Report Share Posted November 20, 2013 oem 18" pegs on D2 No problems aside from the lame turning radius. Volvo's have turning radius!? when did this happen. I aint got $h!T Link to comment Share on other sites More sharing options...
nari Posted November 20, 2013 Report Share Posted November 20, 2013 you must have the jet tuning chip that changes the wheel spacing aswell wut? 235 wide tyres and no rubbing on the strut Volvo's have turning radius!? when did this happen. I aint got $h!T mine has Link to comment Share on other sites More sharing options...
kalvin Posted November 20, 2013 Report Share Posted November 20, 2013 wut? 235 wide tyres and no rubbing on the strut mine has RWD doesn't count. Link to comment Share on other sites More sharing options...
VolvoLuke Posted November 20, 2013 Report Share Posted November 20, 2013 wut? 235 wide tyres and no rubbing on the strut mine has i have 17 inch pegs with 235-45's on them and they rub on the inside all the time. hmm... Link to comment Share on other sites More sharing options...
