Austin_Volvo_Guy Posted December 30, 2013 Report Share Posted December 30, 2013 All, I have a 85 245 and have a misfire that i can not seem to shake. I have replaced all the plugs and wires 2 times with Bougicord, replaced the cap/rotor/coil bosh all the way, and even a nice used distributor off of e-bay Bosch as well.. I bought the car for 500.00, and the previous owner could not figure the issue out. I have brought this to a Volvo shop and they could not figure it out as well, one thing that I found that they did not is the IAC was bad so i replaced. now back to the misfire... this is really starting to irritate me to no end. timing belt is correct, and distributor is correct. any thoughts would be appreciated.. Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted December 30, 2013 Report Share Posted December 30, 2013 Might be a bad injector, obviously you can unplug them one at a time to isolate the cylinder responsible, unplug all four and check the resistance (ohms) between the terminals, all four should be very similar. Otherwise odds are high it's a bad intake manifold gasket, might test by spraying carb cleaner where the runners meet the head while engine is idling, change in idle indicates leak, Relatively easy to DIY switch out, and normally very cheap to buy. Just take the 13mm nuts off, loosen or remove the bolt from the vertical support (IAC is attached to it) and push it back enough to remove/replace the gasket. To help avoid dropping nuts, use a bit of paper towel over the 13mm socket before you put it over the nut. Link to comment Share on other sites More sharing options...
Austin_Volvo_Guy Posted December 31, 2013 Author Report Share Posted December 31, 2013 Three Fat Tigers, Intake gasket is good, replaced along with new injectors,and fuel presure regulator. I also replaced the in tank pickup gas pump and external pump. since the car sat for so long i dropped the tank and had it presure cleaned as well..... Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted January 1, 2014 Report Share Posted January 1, 2014 Do you know which cylinder is responsible? Has there been a compression test, and do you know the results? When does the misfire occur, at idle, at high rpm, all the time? Link to comment Share on other sites More sharing options...
FCP Euro Posted January 8, 2014 Report Share Posted January 8, 2014 Any luck with this? Wanted to find out how you made out. Link to comment Share on other sites More sharing options...
