Tech Posted May 28, 2014 Report Share Posted May 28, 2014 Congrats! I just got mine running again on Sat to! Link to comment Share on other sites More sharing options...
marlint5 Posted May 28, 2014 Report Share Posted May 28, 2014 Nifty looking ECU you got there Boxpin, Kindly comments on your Sachs 707 and Clutchnet 6 pucks combo please. Im following this thread very closely... Thank you Link to comment Share on other sites More sharing options...
boxpin Posted May 28, 2014 Author Report Share Posted May 28, 2014 Boxpin, Kindly comments on your Sachs 707 and Clutchnet 6 pucks combo please. Im following this thread very closely... Thank you So far...sucks. I will say this, it will never slip again. Its a battle to drive it. Its very strong on the pedal. There is not much room for a smooth take off. Its engaged or not engaged. I have been driving it for two days and I came up on some traffic today and all I could think about is how tired my leg was going to be. This is day two though so I am getting used to it and finding that a little more RPMs at take off help a lot. It grips amazing as in chirps the tires in first gear if your not careful. So, after two days: 1. Very hard pedal movement 2. Clutch grabs, there is no denying that. It will hold whatever I throw at it. 3. Tough daily driver I am hoping that with some time it will calm down and become common place. I will report back in a week or so. Link to comment Share on other sites More sharing options...
marlint5 Posted May 28, 2014 Report Share Posted May 28, 2014 Boxpin, Thank you, * a bit worried now, will be running the same set up.... and being not that young anymore.......we will see. Link to comment Share on other sites More sharing options...
mattwebb502 Posted May 29, 2014 Report Share Posted May 29, 2014 very curious to hear your impressions on that new intercooler Link to comment Share on other sites More sharing options...
LaMunyon Posted May 29, 2014 Report Share Posted May 29, 2014 very curious to hear your impressions on that new intercooler Not to thread jack but I just put in a do88 intercooler myself and am thoroughly impressed. I'm running a TMM9 tune, and after installing the do88 with no modifications to the tune the max psi jumped from ~19-20 to 23 and the boost had to be scaled back in the tune due to the added efficiency of the intercooler. Link to comment Share on other sites More sharing options...
woah4 Posted May 29, 2014 Report Share Posted May 29, 2014 I could be totally wrong here but if pressure is a result of restriction wouldn't having more pressure as a result of a new intercooler be an indicator of higher restriction, rather than greater efficency? Link to comment Share on other sites More sharing options...
boxpin Posted May 29, 2014 Author Report Share Posted May 29, 2014 very curious to hear your impressions on that new intercooler Still running the FMIC at the moment. I just wanted to get it back on the road. The DO88 is in place but not piped. Probably a week or so. I am in break in mode. Link to comment Share on other sites More sharing options...
LaMunyon Posted May 29, 2014 Report Share Posted May 29, 2014 I could be totally wrong here but if pressure is a result of restriction wouldn't having more pressure as a result of a new intercooler be an indicator of higher restriction, rather than greater efficency? Truthfully I'm not knowledgeable enough to answer that I was just regurgitating what I was told. Hopefully someone with a better understanding can chime in. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted May 29, 2014 Report Share Posted May 29, 2014 I could be totally wrong here but if pressure is a result of restriction wouldn't having more pressure as a result of a new intercooler be an indicator of higher restriction, rather than greater efficency? Restrictions cause an increase in velocity and a decrease in pressure. Assume in-compressible, inviscid flow aft of the compressor wheel and simplfy the Bernoulli equation if you want to prove it yourself. The D088 presents less of an restriction, which leads to slower air flow and therefore higher pressure. Link to comment Share on other sites More sharing options...
boxpin Posted May 29, 2014 Author Report Share Posted May 29, 2014 Cant remember who posted it but someone said they needed to use spacers on the DO88 intercooler. Maybe they saw that and made some changes but I found that there was zero touching anywhere. No spacing needed. Link to comment Share on other sites More sharing options...
dougy Posted May 29, 2014 Report Share Posted May 29, 2014 it might be cause spacers are nicely welded there in place? Link to comment Share on other sites More sharing options...
boxpin Posted May 29, 2014 Author Report Share Posted May 29, 2014 Not the welded spacers you see, they put washers between the radiator and intercooler because it touched. Link to comment Share on other sites More sharing options...
boxpin Posted May 29, 2014 Author Report Share Posted May 29, 2014 * a bit worried now, will be running the same set up.... and being not that young anymore.......we will see. Trust me, I am right there with you. The pressure plate is strong. The disc grabs really well. The combination of the two makes it a very small window for engaging the clutch. That in combination with the lightened flywheel causes you to have to rev a bit to make the whole thing work. I am going to use it through the breaking period and tuning. Other options would be to use the 707 with the R disc or the R pressure plate with the 6puck. Link to comment Share on other sites More sharing options...
Avinitlarge Posted May 29, 2014 Report Share Posted May 29, 2014 I was reading about the spacers too, its in this post '?do=embed' frameborder='0' data-embedContent>> My Do88 intercooler has just been delivered, will see what happens when I fit it. Link to comment Share on other sites More sharing options...
