quiksilver Posted July 16, 2014 Report Share Posted July 16, 2014 If I remember correctly, Hussein went through a time where he was going to sell the XR. Look where he's at now, think on it and please keep the wagon. Link to comment Share on other sites More sharing options...
lookforjoe Posted July 16, 2014 Report Share Posted July 16, 2014 If I remember correctly, Hussein went through a time where he was going to sell the XR. Look where he's at now, think on it and please keep the wagon. Yeah, After I nearly killed myself with it Her name is Christine...... Link to comment Share on other sites More sharing options...
fwdGTP Posted July 16, 2014 Report Share Posted July 16, 2014 :( Link to comment Share on other sites More sharing options...
NitroX5 Posted July 16, 2014 Report Share Posted July 16, 2014 Edit: I saw you have a RN head...but my theory may still standing Surely you have enough oil press...it must be just a crap sender. When I had low oil press because of the pump gasket fail, the fist thing I really notice it has a diesel sound in every rpm. (low oil in hydros) The light didn't come up. So I really shut out that you have 0.5Bar oil press and nice sounding engine! Link to comment Share on other sites More sharing options...
854TGA+ Posted July 16, 2014 Report Share Posted July 16, 2014 Oil pressure test done? Link to comment Share on other sites More sharing options...
mattwebb502 Posted July 16, 2014 Report Share Posted July 16, 2014 Well sir, how do you feel today? Have you done any investigating? The frustration and anxiety will subside, just give it some time. I was reading back through your thread and took note of all of the fun you had along the way. Don't lose hope! best of luck Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted July 17, 2014 Report Share Posted July 17, 2014 Is not easy, on a different level I been trough the same problem, engine rebuilt with 15-20k on it let me down two days before Carlisle Show, open up and there was the rod bearing on cyl #2, sound like diesel = piston was hitting the head! Is worth to drop the pan and check was going on before you give away all the nice work/time/passion on that car!!!Good luck with the Car. Link to comment Share on other sites More sharing options...
gilber33 Posted July 17, 2014 Report Share Posted July 17, 2014 Just out my own curiosity, why and how does the oil light come on and stay on when you spin a bearing? Link to comment Share on other sites More sharing options...
volvoguy23 Posted July 17, 2014 Report Share Posted July 17, 2014 Because all the pressure is lost at the lubrication hole underneath the bearing... Or oil galley what ever you wanna call it.From the bearing that has been spun.. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted July 17, 2014 Report Share Posted July 17, 2014 Just out my own curiosity, why and how does the oil light come on and stay on when you spin a bearing? The crank has a hollow cavity along its center that is fed by the oil pump. There are holes in the journals that allow the oil to escape and lubricate the gap between the crank journals and bearings. When you spin a bearing the surface is worn down and this gap increases. This gap increase allows oil to flow out around the bearing and into the pan more easily, thus decreasing oil pressure. Link to comment Share on other sites More sharing options...
volvoguy23 Posted July 17, 2014 Report Share Posted July 17, 2014 In other words the oil pressure is very low by the time it reaches the oil sender because the oil travels through to all the bearings before the sender. Link to comment Share on other sites More sharing options...
wizzard_al Posted July 18, 2014 Report Share Posted July 18, 2014 No, the oil pressure is reduced by the large gap in the rod bearings, and that lowers the pressure everywhere. The oil pressure sender gets it oil from around carnk bearing #4? I think, but it doesn't matter which bearing is bad, the pressure is low everywhere. Link to comment Share on other sites More sharing options...
volvoguy23 Posted July 18, 2014 Report Share Posted July 18, 2014 Yea that's basically what I said at the end of page 1. Link to comment Share on other sites More sharing options...
mattwebb502 Posted July 20, 2014 Report Share Posted July 20, 2014 I'm admittedly skeptical of Glyco replacement bearings sold on the aftermarket (sputtered or not... from reading around, no direct experience!), however I wager that this is not a spun bearing but something that is much easier to rectify. Rooting for you over here, Boxpin! Watching this thread and waiting to hear some findings. Link to comment Share on other sites More sharing options...
fwdGTP Posted July 20, 2014 Report Share Posted July 20, 2014 Well, the engine shop didn't tell me there was anything wrong with the Glyco's, at least that I know of, but he said something about running into some bearing issue that raised the price by 200$, but didn't really go into it, but I think it had to do with the stock mains, not 100% sure. Link to comment Share on other sites More sharing options...
