Boxpin's Build
boxpin
Didnt get very much done today. Only loaded the pistons onto the rods and double checked the ring end gaps.
677F649E-8438-4C19-BF95-F671D43D1DBA_zps
3D5C91D3-ED42-498B-9641-AD9F6A39DD55_zps
C41B52DD-86A7-4EA7-BE2F-F3BF240DDCE1_zps
2DCC66C8-809D-40AE-ABAE-FCDC6EB401EF_zps
C0910006-D808-4451-A446-7C0BC0BDFDC7_zps
It looks great so far. Do you need special tools to put the rings on the pistons? Any special steps when installing the rods and pistons? Like do you check the ring gap?
A pair of piston ring pliers will help prevent breaking the rings but I've slipped rings on without them. I don't suggest doing it that way personally. You really risk breaking rings without the pliers.
i have one of those plier but for some reason it was harder to used the plier than just to slide them on.
Do you guys check the ring gap and grind the rings if need be or do you just put them on the pistons as is?
There are specific measurements that the ring gaps go by. Its the bore size x <application chart>. Each ring is measured and ground for the cylinder its assigned to. The chart below is from Wiseco. I paid to have mine done but after getting them home and double checking the gaps, cylinders 1 and 3 had to be touched one more time.
Boxpin,
Just want to double check with you, the Clutchnet 6 puck part number is - 6BS21131?
and any link where you get your Sachs 707?
thank you
Aaron, you know where im heading right?.... :)
