Ol' Dirty Noodle Posted October 14, 2016 Report Share Posted October 14, 2016 1 minute ago, Commander Riker said: That's really impressive man. Do you feel the 4 cylinder white block is better in any regards than the 5? Pretty sure that's the general consensus, ECU tunability is the hold back. Quote Link to comment Share on other sites More sharing options...
gdog Posted October 14, 2016 Report Share Posted October 14, 2016 5 hours ago, VulvaS40T4 said: 707hp vs. 694hp 2.8bar run. Only difference 1 degree more timing after 7000rpm. This is from dyno session on spring 2016. :) 650nm max torque limit was reached so did not try to reach MBT (stock composite head gasket). Outrageously awesome!! Thanks for this thread; it's an inspiration, I am sure, to many of us on VS.. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted October 15, 2016 Author Report Share Posted October 15, 2016 9 hours ago, Commander Riker said: That's really impressive man. Do you feel the 4 cylinder white block is better in any regards than the 5? Only one thing is better and that is divided manifold and divided turbine housing on turbo when using 4cyl engine (better spool and overlap handling). 5cyl is better in everyother way because it can handle one cylinder more power with same modifications. Tune is the most important thing when having lots of power and torque. If its not just right engine wont hold long. :) Thanks guys! I will try to help you as much as i can. ;) 4 Quote Link to comment Share on other sites More sharing options...
Bpc576 Posted October 15, 2016 Report Share Posted October 15, 2016 On 10/10/2016 at 9:06 AM, venderbroeck said: Only if the current spring is too weak from old age. Tightening it to spec often is enough in such a case. Other than that, a stiffer spring than stock will only introduce spiking, and possible rod bending detonation if it's not accomodated for in the tune. The wastegate preload should be around 4 to 4.5 psi. On 5/17/2014 at 0:50 PM, VulvaS40T4 said: what is this second pic of? custom manifold? Just now, Bpc576 said: what is this second pic of? custom manifold? intake manifold?*** Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted October 16, 2016 Author Report Share Posted October 16, 2016 Its custom dual plenum intake manifold with 50mm runners. :) Quote Link to comment Share on other sites More sharing options...
Bpc576 Posted October 17, 2016 Report Share Posted October 17, 2016 On 5/17/2014 at 0:50 PM, VulvaS40T4 said: where did you get this? Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted October 17, 2016 Author Report Share Posted October 17, 2016 My friend has company here in finland and its custom made with my needs.About 1500dollars. Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted October 29, 2016 Author Report Share Posted October 29, 2016 Winter tyres are on. :) Still working great. ;) http://i119.photobucket.com/albums/o143/VulvaS40T4/IMG_20161029_121928_zpshp9akoyv.jpg 2 Quote Link to comment Share on other sites More sharing options...
Commander Riker Posted October 29, 2016 Report Share Posted October 29, 2016 Love your car because of how unassuming it is. We need a video of it in the snow please. Quote Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 29, 2016 Report Share Posted October 29, 2016 Dude are you running stock fucking brakes??? Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted October 30, 2016 Author Report Share Posted October 30, 2016 (edited) 8 hours ago, Ol' Dirty Noodle said: Dude are you running stock poking brakes??? Yes. :D Stops great from 192mph on standing mile with half mile stopping distance. :) Also i don't drive on track where you really need good brakes. On street max speed i drive is 150mph and from that stops also easily with only EBC Yellow Stuff pads on front and braided brakelines front and rear. I havent got single "oops" moment cause of brakes, with 707hp you cannot drive like crazy everywhere. So no need for big brakes. :D Edited October 30, 2016 by VulvaS40T4 1 Quote Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 30, 2016 Report Share Posted October 30, 2016 True, I guess the traffic there isn't nearly as bad as New York City to boot Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted November 10, 2016 Author Report Share Posted November 10, 2016 Gearknob button hides two different boost settings. ;) http://i119.photobucket.com/albums/o143/VulvaS40T4/IMG_20161110_17430701_zpsg3wxlcrm.jpg 2 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted November 12, 2016 Author Report Share Posted November 12, 2016 On 30.10.2016 at 0:54 AM, Commander Riker said: We need a video of it in the snow please. Cold start and winter driving like stock Volvo S40 T4 on E85 and 707hp. :) http://youtu.be/Z7dq32shF00 2 Quote Link to comment Share on other sites More sharing options...
VulvaS40T4 Posted January 7, 2017 Author Report Share Posted January 7, 2017 Quote Link to comment Share on other sites More sharing options...
