Tom. Posted September 21, 2014 Report Share Posted September 21, 2014 i should wash my car... looks good shiny Quote Link to comment Share on other sites More sharing options...
floggingmike Posted September 23, 2014 Author Report Share Posted September 23, 2014 Ur car iz ugly Thom Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 6, 2014 Author Report Share Posted October 6, 2014 Hi friends, possibly looking into a couple P1 m66's in the near future...anything I should look for? It'll just be a unit from a dismantler, so I dont think itll have all the accessories. Also, i know ill have to grind some of the housing to fit the subframe, get special axles (blackT5 did that i believe), hussein bracket, clutch assembly/flywheel, shifter (fortunately p1 shifters fit easier) and i know im leaving other small bits out. but yeah any info about throwing a P1 M66 in, that i probably dont already know off, would be helpful. Thanks! P.S. I have done some reading, I just dont want to miss any important things. Quote Link to comment Share on other sites More sharing options...
T5power Posted October 6, 2014 Report Share Posted October 6, 2014 Have you thought what you'll do about a tune? Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 6, 2014 Author Report Share Posted October 6, 2014 I'm thinking Hilton. Seems reputable and they do manual tunes IIRC Quote Link to comment Share on other sites More sharing options...
volvoskiah Posted October 6, 2014 Report Share Posted October 6, 2014 I'm thinking Hilton. Seems reputable and they do manual tunes IIRC Idk about Hilton but I know tom loves his Steve-O tune......and the fact that his tune is the only one that has ever worked in his car 4 Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 7, 2014 Author Report Share Posted October 7, 2014 When the time comes I'll decide. Hilton does Connor Trudeaus tunes Quote Link to comment Share on other sites More sharing options...
Timbo Slice Posted October 7, 2014 Report Share Posted October 7, 2014 And Steveo does BMac's tunes. Comparing the customers, I'd trust BMac more than Connor any day. This is not a reflection on Connor being a piece of shit or anything like that, but Ben has always been straight up with me with everything I've dealt with involving him. Connor on the other hand hasn't been 100%, such as when he told me he was bringing me perfect mechanical and aesthetic front struts for my car, which ended up being a bit quicker return than expected and full of surface rust. I am in no way bashing Hilton tunes or Connor's recommendation and knowledge, but for the reason that Ben has always been 100% trustworthy I went with a Steveo tune and am very happy. The fact that he easily got Tom's car running is just icing on the cake. 2 Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 7, 2014 Author Report Share Posted October 7, 2014 Intradesting.....very intradesting..... I wasn't sure how Steve-o was with manual tunes, but I'll lean towards him. Hilton, I have no experience with and have only heard about them with Connors tunes. Steve-o on the other hand, has a bit more rapport imo considering he's done more cars of people I know now that I think about it. BUT thats down the road. Tell me about the P1 tranny. How easy is it to swap in as far as the actual unit. What do I need as far as mounts and shit. Quote Link to comment Share on other sites More sharing options...
andyb5 Posted October 7, 2014 Report Share Posted October 7, 2014 You need a Hussein bracket to use the stock tranny mount. Otherwise the transmission itself is a direct bolt-in. You want axles from a 00 XC, your stock ones do not work. You should shave the webbing on the drivers side of the transmission to make it easier to remove the axle should you need to in the future. P1 shifter base has to be modified some to bolt up to our console, but its pretty much a direct fit. Use the shift cables that match the transmission you're using - so, if you have a P1 M66 get the shifter and cables as well. Clutch options are split between either dual or single mass. Stock clutch for that tranny is a dual mass, and I know a few C30 guys at 300+ whp on the stock clutch without problems. An upgrade from that would be the AP Racing (Kalmar Union) setup that Hussein has. A single mass setup would require you to use an 850R flywheel, pressure plate and the Sachs SD693 clutch: 1 Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 7, 2014 Author Report Share Posted October 7, 2014 I was gonna leave it DM for now, I heard its easier to learn on and shit. 00xc axles for both Driver and Passenger? Thanks andy Quote Link to comment Share on other sites More sharing options...
Blockpartie Posted October 7, 2014 Report Share Posted October 7, 2014 On paper a DM flywheel will allow for smoother shifts, it will also dampen some vibrations and driveline noise. In reality it doesn't make much of a difference wether or not you have a DM or SM flywheel provided you know how to operate a manual gearbox. You might need the manual gearbox mount as well. 1 Quote Link to comment Share on other sites More sharing options...
floggingmike Posted October 7, 2014 Author Report Share Posted October 7, 2014 (edited) I dont think I will, you mean the rear mount? Its awd so the angle gear is in place of that. And the m66 is stock dm so im not gonna convert to sm if i dont have to. ALSO is the fact that its internal slave really a big deal? should/can i service it before its installed? Edited October 7, 2014 by floggingmike Quote Link to comment Share on other sites More sharing options...
andyb5 Posted October 7, 2014 Report Share Posted October 7, 2014 Definitely replace the internal slave before you install, if it goes bad you have to replace the clutch Quote Link to comment Share on other sites More sharing options...
Timbo Slice Posted October 7, 2014 Report Share Posted October 7, 2014 It's usually safe to just replace the slave anyways if it's a used transmission. If you don't and you find out down the line (once the car is running) that it's bad, you'll have to take it all apart again. Quote Link to comment Share on other sites More sharing options...
