lcc014 Posted June 14, 2014 Report Share Posted June 14, 2014 My 95 wagon's fan blower motor start acting strange today. Climate control is the basic/manual. When I started the car, it did not come on no matter which setting was 1, 2, 3 or 4. So I left fan speed at 3 and drove off. Once I got onto highway, the fan came back on by itself. In other word, when I accelerated my car above 40 mph, it came on again. This behavior happened about 50%. Once it was on, it will stay on until I turned off the car. Next time to start the car, fan may or may not come on. Any comment on this behavoir ? The fan resistor was replaced about 2 years ago. So that should be fine (hopefully). Thanks, Ching-Ho Cheng Link to comment Share on other sites More sharing options...
r850glt Posted June 15, 2014 Report Share Posted June 15, 2014 Check Power connections by the fan, I had the same problem a few weeks ago. I would hit a bump in the road and fan would go out and then come back on. Could also be switch. Try pulling codes. Link to comment Share on other sites More sharing options...
BEJinFBK Posted June 15, 2014 Report Share Posted June 15, 2014 I'm betting that you need a new motor. High speeds move air through the system and your's is probably marginal and getting a little "push" start. Dry bearings? Link to comment Share on other sites More sharing options...
lcc014 Posted June 15, 2014 Author Report Share Posted June 15, 2014 Thanks for all the responses. Motor was squeaking for a while before last winter. So I would expect the dry bearings suggestion. Link to comment Share on other sites More sharing options...
