At Or Cxracing Coilovers
TIZIO AKA 1 HND MEC
Multumesc mult!!!
Indeed, more attention to details, adjustments.
Is not French is Romanian (a sister in language ,one of the four Latin languages)
Many thanks Zappo!!!
AT plus the adjustable top mounts cost more than the CXR's.
I will give a try to the CXRacing. I will have them installed by the shop in order to keep the Warranty, PA roads are getting only worse.
Do you have the stock front sway, or IPD? IPD would make the install much easier as I don't see adjustable end links as part of the CXRacing setup.
I have front and rear IPD race (two holes) and IPD links, not a fan of the IPD links, i would love a set of adjustable ones, TKI?
I didn't downvote you, but I am offended that you compared Romanian to inferior French language
Sorry. :( It looked similar to me. Please forgive my ignorance.
Adjustable end links have no real street use with IPD bars normally. The only thing they allow you to do is adjust where the bar sits, which will be helpful since you have the adjustable front bar and possible interference with the lower control arm.
I see, thanks.
