Dougy's Sonic Blue 850
dougy
  • 3 weeks later...
yeah i would not use that...window weld should work perfect cause if you spread a nice even bead throughout and once dry it will actually hold it all together especially at spots that would chip off and would be loose, but it would be messy to apply and if you mess up well it will look horrid.
as requested, here is how i secured it.
with 3m windo-weld
look right under R....left this part on each side of the trim piece without applying the 3m so I could hold on to it as I placed it in its resting spot...
I filled the short channel indentations on the dash with 3M...and I put on more on those two sections that I did not put on the 3M WIDO-WELD trim piece left for me to hold it.
product
and all done
  • Upvote 4
Very nice. Thanks for the update and pictorial.
thanks and not a problem. also a note, now that it is permanently glued to the upper dash, it does not screech as it did before...it actually helped that as well and not just the appearance.
