59 minutes ago, dougy said:
thanks.
absolutely fantastic work doughy...
Looks like a very good transition between the housing and the waste gate, pretty close to a 45ish...
Do you think the .63AR hot side will limit you in respects to EGT and EBP?
I couldn't get above 20 psi on my .63ar .50 trim without encountering some pretty bad knock on 93 oct.. Im talking 25 degrees total about 5 degrees per cylinder.
I believe you have methanol injection so you shouldn't have any issue.
~Matt
thank you matt, i bought a combo setup that aaron recommended...i do have meth and run on e85 so we shall see....
here is a comparison 20G VS GT3071R and all finished exhaust manifold to exhaust housing flow transition done to perfection...you can rotate that flange adapter and it lines up perfectly either way.
4 hours ago, Andzey said:
What is the reason of using japanifold instead of R mani?
thank you matt, i bought what aaron recommended...i do have meth and run on e85 so we shall see....
no particular reason just a preference.
lill swirls...:)))))
  • Upvote 5
  • 3 weeks later...
850 an-6 dougy's nuke rail...lol
Garrett gt3071r direct bolt on, less dp/wg setup $1850 shipped biggrin.gif
ss oil cooler lines
  • Upvote 2
On 2/21/2017 at 8:42 AM, apeacock said:
Nice cut out for the AN fitting there. What did you use to get it so clean and uniform?
thanks...this and paper hand sand to smooth out.
http://imgur.com/fd5fSZt
Guest
Reply to this topic...
  Only 75 emoji are allowed.
