stevensane247 Posted January 12, 2015 Report Share Posted January 12, 2015 Just curious. Was also thinking what if I used the RCA outs (new deck) would do the trick to hook straight into speaker system (convert existing wiring to RCA) Link to comment Share on other sites More sharing options...
andyb5 Posted January 12, 2015 Report Share Posted January 12, 2015 So you want to power the stock speakers with the RCA pre-amp output channels on your headunit? yeah that won't work. Those outputs only deliver a low-level signal for an amp. That is why there are a separate set of speaker-level outputs. And it's fairly easy to maintain use of Dolby with an aftermarket headunit. You just need to buy a HU that has built-in Dolby 5 channel processing. Pretty sure this has already been covered, in some pretty exact detail, in your earlier thread in this same sub forum Link to comment Share on other sites More sharing options...
stevensane247 Posted January 13, 2015 Author Report Share Posted January 13, 2015 I have a small case of down syndrome Link to comment Share on other sites More sharing options...
