Johann Posted August 2, 2015 Report Posted August 2, 2015 The R disc doesn't cover the full surface of the 707 PP. With the R PP the "missing" friction surface area isn't present. With my white 850 M66 conversion I tried to use an S60R friction with the 850 R PP. Here it was the other way around. Friction surface was larger than PP surface plus the friction was roughly a mm to thick. I wonder if the 707 also doesn't need a 9 mm thick friction plate. Quote
Simply Volvo Posted August 2, 2015 Report Posted August 2, 2015 I'm a bit surprised by your choice for the ACT clutch, normally you would say that the 707 in combination with the R disk can maintain the right amount of torque for your setup. Any specific motivation tgat you went with ACT? Would be interesting to know, as I am dropping in my 707 next weekend with R disk.He has a m66, he can't use a R disc, different spline count...707 + 850R disc is fine for 700NM. 1 Quote
lookforjoe Posted August 3, 2015 Report Posted August 3, 2015 Coming together nicely. DP looks great. Does it give you room to access the AG flange bolts - I had trouble with that on my first DP.. Are you putting the flex coupler right after the flange?Curious where the silicone heater hoses are sourced - might need to go that route next time I need to replace them. Quote
Brad850 Posted August 3, 2015 Report Posted August 3, 2015 http://www.do88.se/en/artiklar/volvo-850-s70-v70-c70-94-99-heater-hoses.html Quote
Tightmopedman9 Posted August 3, 2015 Author Report Posted August 3, 2015 Coming together nicely. DP looks great. Does it give you room to access the AG flange bolts - I had trouble with that on my first DP.. Are you putting the flex coupler right after the flange?No problem getting to the flange bolts, although the DP needs to come off to remove the BG. Doesn't take much time to undo the V-band clamps though.The car has been together for 2 months at this point, and yes the flex coupler is about 4" after the v-band. And before you ask, yes it is has the interlock liner. 2 Quote
Sledgehammer_1 Posted August 21, 2015 Report Posted August 21, 2015 I'm a little over half stiff right now.7 Pages in and no one caught this on page 2? Hahaha nice one 'Ron! Great thread, its no Saab though hahaha Quote
Tightmopedman9 Posted August 22, 2015 Author Report Posted August 22, 2015 (edited) Finally finished my intake today. The bottom half I did when before I finished the swap and was my first real AL welding experience. No one makes a tight enough mandrel bend in 3.5" to fit, so I had do some more pie cuts. I also added some LS2 coils about a month ago. Edited May 18, 2017 by Tightmopedman9 2 Quote
gdog Posted August 22, 2015 Report Posted August 22, 2015 Very nice! You guys that can weld like that frigging amaze me; very cool indeed.. Stock intake manifold? Temporary? Quote
lookforjoe Posted August 22, 2015 Report Posted August 22, 2015 7 Pages in and no one caught this on page 2? Hahaha nice one 'Ron! Great thread, its no Saab though hahahaThat's right, it's no Slaab... I also added some LS2 coils about a month ago. Nice Work on the intake. Practice definitely makes progress when it comes to aluminum welding Did shifting the voltage axis fix your issues with the dwell? I still haven't yet switched back to mine to see if the table revision resolves the breakup I experienced. Quote
Ol' Dirty Noodle Posted August 22, 2015 Report Posted August 22, 2015 I'm a bit surprised by your choice for the ACT clutch, normally you would say that the 707 in combination with the R disk can maintain the right amount of torque for your setup. Any specific motivation tgat you went with ACT? Would be interesting to know, as I am dropping in my 707 next weekend with R disk.can't use the 850R disc with the M66 because of the different input shaft, the ACT is the same specs but beefier and with the proper 23x1 pline for the input shaft of the gearbox. The Sachs SD693 disc was an OEM ford/mazda disc that works with the 850R pressure plate for use in later M56s or M66s 2 Quote
Tightmopedman9 Posted August 22, 2015 Author Report Posted August 22, 2015 Yes, fixing the dwell map axis and not over dwelling the crap out of the coils helped a lot. Although, I wish I had just gone with the IGN-1A coils from the beginning. I hate thinking about the thin line between a fully saturated coil and spark scatter. I've been keeping the dwell at 3.7ms @ 13v to stay on the safe side. That's gotten me 23psi at .028" with no blowout. Very nice! You guys that can weld like that frigging amaze me; very cool indeed.. Stock intake manifold? Temporary?Ill be fabricating a new manifold soon. I just wanted to get a before and after dyno, so I'm waiting until the car is fully tuned on E85. 2 Quote
adamdrives Posted August 24, 2015 Report Posted August 24, 2015 Looks great! Looking forward to hearing this bad boy run Quote
adamdrives Posted September 25, 2015 Report Posted September 25, 2015 Any updates with this build? Quote
Tightmopedman9 Posted September 25, 2015 Author Report Posted September 25, 2015 Just replaced valve stem seals and re-did the cam cover crankcase baffles. I dropped a keeper that I assumed flew out of the valve cover. I guess it didn't... Motor may need to come out, I'm waiting for the morning for a full diagnosis. Quote
Yellow95 Posted September 25, 2015 Report Posted September 25, 2015 How would it have flown out of the valve cover? Quote
