apeacock Posted March 25, 2016 Author Report Share Posted March 25, 2016 So today became shave day. I may have gotten carried away with the lower fins and in the end smoothed it out a bit. That lower fin was 90* at one point (oopsie!) "smooth" I promise I read through stuff and looked at picture before I started but it is was it is. 2 Quote Link to comment Share on other sites More sharing options...
apeacock Posted March 27, 2016 Author Report Share Posted March 27, 2016 (edited) Easter Sunday Update, Recieved the coupler from Amazon, It looks exactly like every other one out there and is probably made just as bad as the ones that cost $34-$59. $59 for this!!! Mine was 9.99 The only place I could find a plug was at Lowes, it is a 3/8-24 x 1/2 Socket head set screw. It threads about half way in and then stops. I wound it back out, then in and then out and got it tightly locked in there. The threads are cut really poorly. I also took a round file to the inside to knock down some left over metal from the threading process. Edited March 27, 2016 by apeacock 2 Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 27, 2016 Report Share Posted March 27, 2016 Is that for the rad hose mod required when using the P1 version M66 in a P80? I don't know the details on that... Quote Link to comment Share on other sites More sharing options...
andyb5 Posted March 27, 2016 Report Share Posted March 27, 2016 20 minutes ago, lookforjoe said: Is that for the rad hose mod required when using the P1 version M66 in a P80? I don't know the details on that... Yes it is. Quote Link to comment Share on other sites More sharing options...
lookforjoe Posted March 27, 2016 Report Share Posted March 27, 2016 On March 23, 2016 at 11:47 AM, apeacock said: Took a minute today to install the new detent and the reverse light switch/detent. Thought I was having trouble shifting at first and then I switch the cables on the shifter itself. Seems to work great, really slots into each gear and as AndyB5 has said to me it's hard to hit reverse when going to 6th. Did you transfer the firewall grommet from the old cables? I couldn't get the C30 grommet to line up no way no how. Slit the sheath on one side & then siliconed the slot after proper cable alignment WTF IS GOING ON ON THIS poking SITE. IMG TAGS DON"T WORK NOW????? Quote Link to comment Share on other sites More sharing options...
apeacock Posted March 28, 2016 Author Report Share Posted March 28, 2016 10 hours ago, lookforjoe said: Did you transfer the firewall grommet from the old cables? I couldn't get the C30 grommet to line up no way no how. Slit the sheath on one side & then siliconed the slot after proper cable alignment http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/F932076A-FCF4-4F9F-8F37-BE1E30C9ADF3_zpsbbk04pj3.jpg[/IMG] http://i27.photobucket.com/albums/c190/huseinholland/CarMods/M66%20Brackets%20Shifter%20Parts/1DE08367-B515-4D8F-9EE8-E0A1D68CF376_zps7uukinaw.jpg[/IMG] WTF IS GOING ON ON THIS poking SITE. IMG TAGS DON"T WORK NOW????? H try imgur.com you can sign up with a gmail account and have control over the images in a similar way to photobucket. No plans for the grommet yet. still has the s40 on there. I'll have to tape over it or something crappy for now and wait until there is a manual p80 at the yard and take the boot. Good suggestion though. The grommet isn't available as a separate piece so time to play the waiting game a bit. Really hoping the helper spring comes to tasca in time and I get it here by Wednesday. Ordered it on 3/4, they messed something up and had to re order it again. Quote Link to comment Share on other sites More sharing options...
babyclaude Posted March 30, 2016 Report Share Posted March 30, 2016 I'm pretty stoked for your manual swap. Should be a good weekend. 1 Quote Link to comment Share on other sites More sharing options...
apeacock Posted March 30, 2016 Author Report Share Posted March 30, 2016 2 hours ago, babyclaude said: I'm pretty stoked for your manual swap. Should be a good weekend. Many a wrench will be had! Quote Link to comment Share on other sites More sharing options...
andyb5 Posted April 1, 2016 Report Share Posted April 1, 2016 Swap has started. As of tonight, motor/subframe is out. Good progress for about 5 hours of work. 2 Quote Link to comment Share on other sites More sharing options...
apeacock Posted April 1, 2016 Author Report Share Posted April 1, 2016 Most time consuming single part was the AC compressor line and that's because we refused to take the fan out for 45minutes 2 Quote Link to comment Share on other sites More sharing options...
Domo Posted April 1, 2016 Report Share Posted April 1, 2016 subscribed I'm next to do this swap Quote Link to comment Share on other sites More sharing options...
babyclaude Posted April 1, 2016 Report Share Posted April 1, 2016 5 hours ago, apeacock said: Most time consuming single part was the AC compressor line and that's because we refused to take the fan out for 45minutes Cough*Told you and andy to take the shroud out*Cough 1 Quote Link to comment Share on other sites More sharing options...
Timbo Slice Posted April 1, 2016 Report Share Posted April 1, 2016 Nice work. Where are you guys doing the swap at? I'll have to swing by sometime and bring my C70 for a 426 party :D Quote Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted April 1, 2016 Report Share Posted April 1, 2016 2 hours ago, Timbo Slice said: Nice work. Where are you guys doing the swap at? I'll have to swing by sometime and bring my C70 for a 426 party :D Thats at Andy garage, you can see his car on the background! 1 Quote Link to comment Share on other sites More sharing options...
andyb5 Posted April 2, 2016 Report Share Posted April 2, 2016 On April 1, 2016 at 1:46 PM, Timbo Slice said: Nice work. Where are you guys doing the swap at? I'll have to swing by sometime and bring my C70 for a 426 party :D On April 1, 2016 at 4:25 PM, TIZIO AKA 1 HND MEC said: Thats at Andy garage, you can see his car on the background! Yup, our garage on RPI's campus. We had a 426 wagon party earlier: Eric (leco510) myself, and Chris (huntec) while Anthony's wagon is on the lift. 2 Quote Link to comment Share on other sites More sharing options...
