TorontoR Posted September 22, 2015 Report Share Posted September 22, 2015 Hi all...I have set of rep 18" nebs i want to put on my 00V70R. Just wondering what the best tire size is to go with to avoid rubbing. I know the reps have different offset that the oem ones. I'm running koni sports and HR springs on the front, stock in the rears (for now...) Link to comment Share on other sites More sharing options...
Timbo Slice Posted September 22, 2015 Report Share Posted September 22, 2015 If it helps, I ran 18x8 Capellas on my S70 with 225/40/18 tires. You should have the same amount of clearance on the wagon. I ran Koni adjustable dampers with iPd blue springs and had no rub with proper spacing. Link to comment Share on other sites More sharing options...
Avinitlarge Posted September 22, 2015 Report Share Posted September 22, 2015 Im running 225 40 18's on Pegs, 97 V70 R lowered 40mm. I do get a TINY bit of rubbing on full lock Link to comment Share on other sites More sharing options...
NEU Posted September 26, 2015 Report Share Posted September 26, 2015 If it's the Nebs with 38et you can run as wide as 235/40-18, that's what I run on my Ultraleggera in the same offset. I'm also running Yellows with H&R and had very minor rubbing at full lock and at the outer lips of the fenders front and rear. If the Neb are the 49et you'll have to run a 10mm spacer to stuff those under there with that rubber size, I'd run spacer with that offset anyway. Keep in mind that the AWD rear axle is wider then the FWD so you will have to pay more attention to the outer lip for contact. Link to comment Share on other sites More sharing options...
