On 12/3/2015, 7:56:38, lookforjoe said:
Thanks. Didn't know that about PA. Makes sense, though - on how clean the car is.
Started work on cleaning & mild porting of a lower intake manifold. Since the Elevate has larger ports, figured I might as well take advantage....
NY uses salt on the roads, I believe PA only uses sand.
3 hours ago, Ruhl98t5wag said:
Let's see the tool kit all in one place please. Thanks
Not sure what you mean - what I'm using to clean it up?
I can take a pic later. Basically it's carbide burr tools, than dremel sanding drums then different grades of sandpaper then wet&dry sandpaper, then steel / copper wool, then rubbing compound with a dremel wheel, then by hand
there is plenty of salt and brine on the roads here in south east pa... I see more salt here then I did living in Syracuse... but people in Syracuse actually knew how to drive in the snow for the most part
The manifold looks great! I too would like to see the tool kit you used... dremel and drill with many attachments?
Yes the descending tool kit for smoothing the casting surface. I have carbide burrs, dremel bits, and paper, just want to see a kit from someone who has labored this job efficiently. I'm going to do one this winter-Thanks
This is the mess
2E22F682-54DF-4C48-AF5E-C968AAFAEE67_zps
getting there  - still have a little cleanup inside - follow the casting lines
934E06BF-1A52-49CF-B9D7-87D0AE2571CE_zps
spent some more time on the outside. Not sure why I'm bothering - 99% is not visible. Trouble is, once I start, it's hard to stop :a-farmboy:
79EEEB1A-2BBB-43F6-845A-F87137035C13_zps
19381E62-3600-4FAA-8BE5-9488C966CB8C_zps
  • 2 months later...
Slowly making some changes.
New right side mount
709663AF-16BD-4140-A80F-AB1E7FA45738_zps
removed the 'shock load damper' from the clutch vent pipe ready for when I do the Wavetrac/Spec Clutch install
E341BAE0-D22A-4674-BF14-6F5A4AC8918A_zps
Working on a larger IC
9C113020-A8CA-4326-8EC6-9839F5999BC0_zps
Welded the EBP bung to the K16 Manifold
1F5C8831-31F5-40E3-B277-AA3A57C13908_zps
Installed modded lower runner, new breather box
D8255EE1-1BCA-4C89-B977-C06E730E556D_zps
03892B9C-098F-4C72-914E-B23A58710E05_zps
Fitted the S60R spare - need it to clear the BBK's.
55A997A1-9602-4F32-B406-E70B9E3F0711_zps
Had to make new hinges for the cargo cover
47828796-4447-4069-A6ED-3A610FC3BDEB_zps
QTP Exhaust Cutout will be going back here
E85DF07F-528B-42DD-8004-A28605B7A861_zps
5741D96A-EC05-4459-A5DE-4336BCC1006F_zps
KYB adjustable rear shocks
F932E377-A41D-4BB8-9E2B-67849344093C_zps
Worked on the exhaust yesterday. Cut off the stock exhaust & made a 3" SS section to run from the Mototec DP back to where the cutout will end up.
Didn't like the transition from the 3" DP to the 2 3/8" stock rear section.
92092854-66D3-46D0-B24D-B2AF492360BB_zps
Going to use a smooth transisiton 3" - 2.5" step coupler after the Vband to connect with the rear section. Down the road I can swap out the entire rear and make a 3" setup if need be.
Used 2 Pypes Performance Exhaust SS PVM4590-30 & 1 Pypes Exhaust SS Mandrel Bends PVM3018-30. 1 Vibrant 1473S 2 Blt SS Exhaust Flg 3", 1 Vibrant 1458 2-Bolt High Temperature Exhaust Gasket. 1 x 3-2.5" SS step coupler . 1 x SS 3" Vband
E1767B56-DB6D-4717-BB54-99767666E808_zps
3B7A2E47-45EC-4720-BD13-46153178E157_zps
85029EF5-2943-45C6-A5AB-B1D56EF3B59A_zps
9B4099C6-FAB7-474A-9FF6-547453C80344_zps
965B0D08-91B0-419F-954F-54C78A89D59E_zps
Step coupler will go on the old pipe, with a V band to connect to the 3" section
7F837D05-F041-4631-A649-C89C365CFA9D_zps
Nice car!
But.. Dont use that crappy chinese intercooler!
The ones from EuCD platform is basically bolt on and a great upgrade! Especially if they are from VEA generation. We have one working great on a 500 hp S40 T5 AWD.
Also the intercooler from V40 is quite good and should be a very simple install (i.e. even more "basically bolt on").
(my thought on the DO88 ones are that they are heavy and thats why they work for a shorter pull but they are not so good in getting down in temp afterwards = not good on a track car).
Nice with the exhaust upgrade! We have run a quite stock T5 with 3,5" downpipe and 2,5" rear and that hade quite the back pressure due to the high flow the K16 is able to generate. 3,5" works all the way on AWD and with cut-out is a very good system where the large silencer in the rear could be bypassed all together but still using the exhaust tip.
BR
Erik
Some of my welds aren't so pretty - Still getting practice welding SS. It's way easier than Aluminum, but seems pickier about having a clean tungsten. My near vision in low light is not good, so even with reading glasses I can end up wandering ;)
I'm using the stock rear can for now. This way I have no drone unless I open the cutout :)
I can build a rear section & just tie it to the Vband I added over the rear suspension later on.
Got the step down, V band and cut out dump tube welded today
0E8B2C3B-0128-4E14-BAF3-F6B2178826B3_zps
May have to extend the cutout shroud to make sure the exhaust doesn't melt the inner fender liner rear lip.
A928C5D7-AECE-404C-8C8A-94A651955D45_zps
I ran the wiring through the rear panel where the license plate harness exits the cargo area. Can't get the frigging grommet back in place - the access hole is just a little to offset relative to the grommet hole, and there's not enough space between the tie bar and the rear sheet metal to get my arm up that high. I'll figure it out later. Coming down with whatever bad cold/flu the Mrs. has, so everything today took twice as long as it should have. I also nudged the alignment of the Vband on the rear section after I marked it all up, which has the effect of kicking the right side tailpipe about 1/2" or so further out than the left. Very annoying. No way to fudge it, as there is no wiggle room with lipped Vband flanges. So , I'll probably remove the right tail pipe & reweld it in the correct orientation.
What I need to do first, is wire the cutout.  I need to find a 12v switched power supply in the cargo area for the wireless transmitter. Any ideas? I don't really want to run wires all the way through the cabin unnecessarily.
1 hour ago, fyrken said:
Nice car!
BR
Erik
What year S40 IC are you reffering to? VEA Gen? Any pics? I'm waiting for Bell Intercooler to get back to me on a revised design of their original IC - the one DO88 copies.
The one in the pic is 8x3.5x24" core, with a deflector added to the inlet to push air up. Can't be worse than the Elevate I have no, which is tube & fin, and reportedly not great for the K16 if DO88's graphs are accurate. No reason to believe that are not.
He is referring to cars that have the new engine generation - ''Volvo Engine Architecture'' or VEA for short. All EuCD cars e.g. S80 II, V70 / XC70 III, XC60, S60 II, V60 have received those newer engines. The intercoolers used on these cars are very similar in design to what your C30 has (plastik endtanks with the pipes angled back, aluminium core). P/N #31338236 is for the general use intercooler that Volvo installs in all of the above listed cars with the new engines, in this case the models badged as "<car model here> T5".
When looking up that part don't be surprised that it is also listed for cars with a diesel engine. Volvo has decided to have one basic engine design for everything, they just bolt on different parts. And change the bore and stroke but that's a different thing.
