lookforjoe
On October 6, 2016 at 4:28 PM, andyb5 said:
Just post the direct link to the image and the site will automatically embed the image
Probably cos I was trying to do it from my phone - the PB links seem more convulted that way
E004ED6D-9A7C-49BC-9020-E83E31408D4B_zps
didn't like the bump out where the rear met the fender
A3B16477-CEE9-4885-B6C9-DE1B276BDF44_zps
so I filled it & made a crease line
6071B778-B796-4C84-B2D9-77A4337E37DE_zps
6E25D41F-A95D-44B9-9486-1E2ABB162114_zps
E0DA0904-3148-46D1-8259-30881214A10B_zps
fender tops look pretty well blended now
C23091B1-BE64-4617-93EA-A196EA97359D_zps
6F1ED55E-0918-4F23-BBEB-1E2166070CC6_zps
ADED7528-2977-4E06-B86E-CF0DCCE7723E_zps
D4656AA8-E67F-4F73-870B-2A38AADB8E8C_zps
EDIT: Widened the rear spoiler to match the fender lines
864A24B6-9149-4959-B4D9-20D629DEE67C_zps
48721B2D-DE9D-4EBD-885F-0A86442D2B98_zps
581BA4EE-26F4-4754-806B-AFA66ACA0762_zps
  • Upvote 6
  • 2 weeks later...
  • 2 weeks later...
Got both doors cleaned up, primed & installed. Modified C30 rockers fitted.
Worked on some low spots
E06AD54C-21D2-4A35-B992-2526F72B5325_zps
AA1B7686-1133-4838-9D76-DB1B44A5C1FD_zps
reworking the original larger engine cover, it feels more in keeping with the larger rear
had to bead blast the seams &  rebond the inner to outer panels
122AF6E5-4047-4304-8C19-5568B79AA84F_zps
Primed
0CE6AFA1-479A-41E1-8B69-FD06779CAF47_zps
  • Upvote 3
  • 2 weeks later...
Still more detail filling/blending to go - after these pics I did more work on the front fender caps, the rear spoiler, and added some meat to the side of the front spoiler where it was tapered to level off the upward sweep of the stock lip
436A9A19-BECE-42F5-9DCC-0723B93131D5_zps
BFAADEAD-4651-4DE0-A890-A17B27ED5BB7_zps
D2BC0EE4-F60F-40D1-B959-30796AE759EE_zps
411385E1-6C94-404D-B2EB-C32C2D085CC4_zps
repaired front lip where it was damaged by flatbed after HG failure
7C3EA4D4-D52A-4DF9-B817-BA5DC1796709_zps
fattened & tapered the side up into marker light region, and removed 'wobble' visible in 3/4 shots
before
3AF79746-B75A-46AB-8C9A-4B98BF5945B5_zps
after
839DBE22-7701-4BA0-A892-032749CD2D17_zps
before
E62B90B9-FD8E-4AA5-885E-C4260AFC465B_zps
after
C16C634C-13E0-4DCC-B72C-9460F814484F_zps
unless I get lucky, the avergae temps now are 40ºF range, so too cold to continue with any bodywork.
  • 1 month later...
Chopped up the instrument cluster to move the tach next to the speedo
88C2442C-9054-43AD-8B3F-CE6960086BC1_zps
B1F39B24-4E16-402F-8EE7-190E8467D534_zps
D60C169F-3E0A-479F-90B1-4C8263E29C99_zps
adding some v70 and 700 content - idiot light cluster & film
8E57D7F4-8F6B-485A-97FA-D3DE8FA65E08_zps
4F4298C3-80FC-486B-9257-CB2A634E3798_zps
little bit of circuit wiring
rewiring the harness
A7542DD6-B10A-4B65-AD5F-C329BE8B4B10_zps
finally, view through the wheel :)
10DD797A-9A8A-4B3D-B249-88E96F13A1E2_zps
EZK 116 with wasted spark mod
14F9CA86-DB73-408B-8E24-2AE43CB5B0BF_zps
2DC9947A-CA69-4440-9B9A-A26B88EA184A_zps
0031A172-D7D3-42F8-9CCF-FA7B7B5E4CF7_zps
Harness...
0383FA29-75AD-4ECD-B71A-CA8F3F34BA3E_zps
Coil placement
E707759C-75AF-4744-9695-B351C6FBF714_zps
Power stage & heat sink
9E73C833-0E62-48A4-A752-86062CFFFC44_zps
Kingsborne custom plug wires in, distributor removed (Fiat made a blanking plug for cam mounted distributor setups)
09B7FACE-A73E-4F4A-B2BD-0012A0F62ED1_zps
tach pulse relay
1F225802-5CAE-4F1E-A1DC-E37FF4C6E61D_zps
  • Upvote 2
  • Downvote 1
Had some time to read through all of the fiat stuff. Very cool stuff going on.
I really like how you use other parts from other cars (s2000 seats, x70 center console, x70 warning lights in the dash, etc).
Speechless on the body work for just doing it at home! Looks fantastic.
Will you be bringing this car to Carlisle this year?
Edited by Simply Volvo
  • Upvote 1
Thanks, Matt.
Still hoping to paint it myself also - see how that goes with the 2K prime coat...
I will be driving this to Carlisle - the K16, etc. on the C30, won't happen until the X1/9 is mostly done.
Built a Bosch Powerstage (960, M4.4) setup to run instead of the Mitsu - less wires, easier to locate spares for me. Mouser has all the AMP 2,3 & 7 pole connectors.
59A70047-9D31-4EEF-9F74-A7ED32BC7604_zps
2F0F6749-78C5-44DE-B627-6C3EA175A711_zps
87FA4C68-56D1-4D48-8444-1542FA5D0991_zps
C30 stuff - rewired the fogs & brakes, added two additional brake lights - following Gerrit's (TheBelgian on C30) directions. I used Volvo conenctors instead of scotch locks & American spade connections ;)
E7C11F14-C8F5-45B1-899D-4466AED7442E_zps
C6B4984D-1C54-4DA3-B5E8-4EBCF914231F_zps
B1FA68DA-C78D-484F-B7D2-4225A7F8FCDD_zps
tested the wiring
0A7DEC1D-44CD-4D36-8EB6-0FF06A1501AB_zps
17243BDF-EE64-4F7C-8472-4D13ACBE5E73_zps
Gonna fix my foglight - bypass the CEM & wire them through a separate pulse relay.  The factory wiring appears to feed juice to both sides of the fog relay, and uses the pulse from the foglight switch to inform the CEM that it is OK to ground the (85) terminal of the fog relay, thus turning on the fogs. In my case, the CEM is refusing to do so, even though I have paid for the fucking software, and Volvo cannot figure out why it won't accept the signal. Did I mention I hate all this software reliant operation? Bunch of fucking crap.
Screen%20Shot%202017-01-15%20at%209.35.2
62DFEB71-F0F9-4A5C-8293-28945AE04D7B_zps
Removed the CEM, Removed G:9, B:23 & A:32 & added pigtails to feed the new relay,
99CF6F41-C3CA-477B-A09B-9CF813120A8A_zps
terminating at this 6 pole JPT connector, which the relay will plug into
C4FC95D3-72CB-4594-98EF-2F4BC803EE01_zps
Using stock ground point
AA9A1CBA-6854-4DBB-91E2-CF12BA66E132_zps
However, that relay didn't work. The signal from the stock foglight switch (to B:23 at the CEM) engaged the new relay, but caused it to 'strobe".
So, I've made two alternatives to try.
Manual on/off switch integrated into headlight switch. This will switch a standard relay to ground, turning on the fogs. power supplied from the light circuit, so no fogs if the lights are off. Fogs will stay on with high beams.
155AA73F-D556-487D-81A4-2CA04A43E1E7_zps
25FE5552-3F56-4849-A703-3A84495694F8_zps
Alternate is a Volvo overdrive relay, which relies on a trigger signal to turn it on/off. This will make use of the existing momentary feed from the stock foglight switch. Power will be switched from the light circuit also. Won't know until tomorrow if it will work. I'd rather keep the dash switch stock, so this is the preferred option
08C50400-3AD7-4E90-AF2B-2E3FBA144FD4_zps
Guest
Reply to this topic...
  Only 75 emoji are allowed.
