29 minutes ago, Ghost Shadow said:
H,
are you going to remove and retint the rear glass. 3pc tint looks hideous.
Also question about the front brakes, are the bleeders supposed to be on the bottom or the top?
Yeah, I don't like that. Good catch. Will need redoing. Why the heck would someone do that in the first place???
The bleeder nipples face up  - the pic with them down is the rear caliper - I have to switch balance tubes & bleeders with the rear mount location on the C30
4F949DF8-BC64-4F77-8C9E-28DFD22D5668_zps
The two babies12240439_10153049824476370_8574869405826
  • Upvote 4
On November 18, 2015 at 2:20:49 PM, Timbo Slice said:
Or buy an already built (read: factory supercharged) car for that matter :wink:
And nowhere is there a "build thread" for my car.
Many, Many thanks to Kissinger on C30Crew for his pics of the CEIKA setup on his C30 - Helped immensely with installing the lever & cable bracket in the correct orientation
brackets & eBrake mechanism
BEDAD929-C5CF-4B98-9D6D-2239EE29A19A_zps
Hoses they provided were too long, so I used the ones from the V70 (R1405008)
EC47EF0A-B44F-4A6D-BE4D-E4DE42BFC4D0_zps
cable & hose routing - I used the little hose support they provide  to locate the hose on the outside of the original bracket, and used the original to route the cable without any harsh angle changes
7E8577E5-7412-4646-B13D-75546AB70D6C_zps
456B0103-CD0F-4AAB-B29C-3DDCAA50D69A_zps
88ABEB4D-79C1-44C8-A8FC-A6065C6A8CBD_zps
2651D5AC-D4A1-42B5-AC5B-7AD7A572F044_zps
E3E7CF1A-F788-4617-8C83-DA05F5E82BDB_zps
11C006CB-6857-4840-99E5-24D7963E9134_zps
  • Upvote 1
Wow, underside of the car looks extremely clean. Where did you pick the car up again? I know you'd have a tough time finding anything that rust free in your neck of the woods.
Posted (edited)
Came from PA, about 5 hrs. Similar weather though, so maybe it was garage kept, I dunno. It is very clean overall. Re bled the calipers yesterday & installed the pedal covers
6F667CFF-3D35-41AA-8DCB-30BB473E2C59_zps
F5E9A2DE-3FAE-4018-82A4-36D7224EFF3C_zps
3E055355-385F-400B-B880-E78B09113438_zps
0C730D26-C161-41EA-A34E-F4B461ADE2F4_zps
Edited by lookforjoe
  • Upvote 3
On November 28, 2015 at 10:32 AM, Kevin. said:
after driving my wife's C30 for a few days, I don't think I will be buying another P80 for a long time
Indeed. It is a nimble car. The significant weight reduction makes it fun even with stock(ish) power levels. It feels pretty darn good with the Elevate 15psi tune. Looking forward to the K16, though.
You should do the WALK mod & a stiffer rear bar - those really make the handling much more fun in maneuvering.
Adding a Parrot MKi9100 for handsfree phone (annoying that it doesn't come with this - even the 2012 Fiat500 has handsfree phone) - gonna put the OLED here
C4E849DD-48D5-411B-9ED0-AC7C419D8A51_zps
controller here
3789E7D4-AE69-40EC-845C-32045B140849_zps
Snabb 3" Inlet pipe installed
2E88E377-ECEB-40FC-8958-9CF4D6EBC101_zps
  • Upvote 1
Note: Had to add a 10mm spacer sleeve to the cable adjuster inside - as it was, the adjuster was completely backed out & the eBrake had to be pulled as high as it could go to get any real effect. With the sleeve, the lever position is back to stock, and adjuster barrel is about halfway
12294973_10153061597171370_2027077182_o_
Looks killer man. Seeing this makes me wish I went this direction rather than the XC90 mainly because I'm bored, but the extra room and V8 are nice.
And yeah, makes sense why its so rust free coming from PA. The weather may be similar but they don't put a drop of salt on the roads.
Thanks. Didn't know that about PA. Makes sense, though - on how clean the car is.
Started work on cleaning & mild porting of a lower intake manifold. Since the Elevate has larger ports, figured I might as well take advantage....
D0B45729-4B9C-426A-9743-9224FBCB259F_zps
Learn new shit all the time - I didn't know the RNC breather system included venting the head into and out the manifold (square ports & holes directly above).... Cool stuff
0740F1AC-13EF-4BAC-A6A6-55A686E99871_zps
Posted (edited)
Ha! Ha! We all knew that he couldn't just leave well enough alone....and be performance happy with just simple bolt ons, lol! He's about to inspire another whole host of enthusiasts on a different platform....much like he did with the V70.
Edited by 1fastglt
  • Upvote 1
Guest
Reply to this topic...
  Only 75 emoji are allowed.
