dougy Posted February 17, 2016 Author Report Share Posted February 17, 2016 i'll get another one ... but antenna ring tested fine. Quote Link to comment Share on other sites More sharing options...
dougy Posted February 17, 2016 Author Report Share Posted February 17, 2016 (edited) so i was quoted 500-600$ by volvo dealer...immobilizer , antenna ring, new keys and software... plus labor...lmao...came home from work and got her running = 0$ Edited February 18, 2016 by dougy 2 Quote Link to comment Share on other sites More sharing options...
gdog Posted February 18, 2016 Report Share Posted February 18, 2016 Good job! So what was the no-start problem? Aren't dealers hilarious?! Quote Link to comment Share on other sites More sharing options...
dougy Posted February 18, 2016 Author Report Share Posted February 18, 2016 thanks ... unplug the battery for 1 to 3 minutes...reconnect the battery ... key in door-lock , lock - unlock x 5 ...repeat if it did not work. 2 Quote Link to comment Share on other sites More sharing options...
Stefan Mohammed Posted February 18, 2016 Report Share Posted February 18, 2016 You're using used bearings from different engines? I'm guessing you looked at the block/crank bearing codes for each engine and worked backwards from there to find out each bearings 'colour' and then you swapped all the good/correct bearings into this motor? Am I right? Quote Link to comment Share on other sites More sharing options...
Johann Posted February 18, 2016 Report Share Posted February 18, 2016 3 hours ago, dougy said: thanks ... unplug the battery for 1 to 3 minutes...reconnect the battery ... key in door-lock , lock - unlock x 5 ...repeat if it did not work. Glad it works this way. I assume that unplugging the battery would be similar to a reset for the learning functions. You didn't accidentally flip the key 180 degree? Congrats having the engine running! Appears to run smooth. You might check the converter at some point if it isn't damaged or clogged because of the oil in the exhaust. Quote Link to comment Share on other sites More sharing options...
dougy Posted February 18, 2016 Author Report Share Posted February 18, 2016 6 hours ago, Stefan Mohammed said: You're using used bearings from different engines? I'm guessing you looked at the block/crank bearing codes for each engine and worked backwards from there to find out each bearings 'colour' and then you swapped all the good/correct bearings into this motor? Am I right? pretty much...i measured them and used the be best out of all. Quote Link to comment Share on other sites More sharing options...
dougy Posted February 18, 2016 Author Report Share Posted February 18, 2016 (edited) 6 hours ago, Johann said: Glad it works this way. I assume that unplugging the battery would be similar to a reset for the learning functions. You didn't accidentally flip the key 180 degree? Congrats having the engine running! Appears to run smooth. You might check the converter at some point if it isn't damaged or clogged because of the oil in the exhaust. thanks Johann , let us all criss cross our fingers and toes and hope that is stays/runs that way...lol...unplugging just the the battery did not work , I tried that over and over... i did not flip the key I promise lol...for converter i pored a gallon 100% concentrated degreaser down the DP and let it sit then pored 2 gallons of hot water ,took a HD leaf blower to that DP hole and hit it full blast for 10 minutes twice...seeing the stuff that came/blew out I am certain it is clean now Edited February 18, 2016 by dougy . 4 Quote Link to comment Share on other sites More sharing options...
dougy Posted February 23, 2016 Author Report Share Posted February 23, 2016 i got everything working perfectly ... still have to make new turn stopper for LCA's out of aluminium and take the ABS module apart and re-solderer all points cause i get intermittent lights /codes for it. 2 Quote Link to comment Share on other sites More sharing options...
dougy Posted February 24, 2016 Author Report Share Posted February 24, 2016 my front safety belt release buttons did not function properly, so i replaced them both...and made my own turn stopper ,they are same thickness as OEM but from aluminium so they'll never wear out and turning radius is the same...LCA are tapped and nuts on the other side...overkill, nooou - dougy style... Quote Link to comment Share on other sites More sharing options...
TIZIO AKA 1 HND MEC Posted February 24, 2016 Report Share Posted February 24, 2016 Antenna ring mostly, I have a few for sale if you need one just saying! Quote Link to comment Share on other sites More sharing options...
dougy Posted February 29, 2016 Author Report Share Posted February 29, 2016 antena ring was not the problem but I got rid of the headlight wiper holes in the bumpier ...got the trim from s60 with same color code...cut and belt-sanded to shape to fit perfectly and I used blacks adhesive silicone...same as i did on my s60r. http://forums.swedespeed.com/showthread.php?202438-Headlight-bumper-wiper-holes-plugs 2 Quote Link to comment Share on other sites More sharing options...
dougy Posted March 1, 2016 Author Report Share Posted March 1, 2016 (edited) who would have thought a free s60r obx dp does not just bolt right on to C70 ??? ...lol... well now it does it is time to call Hilton tuning and see what R 2.5 liter 16t can do... Edited March 1, 2016 by dougy 2 Quote Link to comment Share on other sites More sharing options...
Commander Riker Posted March 1, 2016 Report Share Posted March 1, 2016 Any under car shots? I need to figure something better for my VR. Quote Link to comment Share on other sites More sharing options...
dougy Posted March 1, 2016 Author Report Share Posted March 1, 2016 i'll take some for you tomorrow...anything specific? Quote Link to comment Share on other sites More sharing options...
