JA VOLVO Posted April 4, 2016 Report Share Posted April 4, 2016 The gas door will not open with the switch on the door. Trunk pops from the same switch with no issues. I hear a "click" under the dash when I pull the release for the gas door, but it does no open or make any noise at the door. The manual release works fine, so I assume the mechanism is not stuck. I looked around but cannot find a fuse that relates to the door. Any ideas on what I should check? I am kind of lost here. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 14, 2016 Report Share Posted April 14, 2016 I would first try seeing if you have power at the lock motor when the switch is activated. This would isolate a circuit vs. component failure. Link to comment Share on other sites More sharing options...
JA VOLVO Posted April 15, 2016 Author Report Share Posted April 15, 2016 Thanks! I will be digging into it this weekend. I will post up what i find. Link to comment Share on other sites More sharing options...
