On 5/2/2016 at 2:33 PM, Oreo931 said:
Now to the bad part :( . I sprayed the plastic piece with a coat of black SEM interior paint. For some reason, the repaired portions of the plastic stood out like a sore thumb. My next idea was to try and cover up these imperfections with some textured paint. So I sanded the area down, and sprayed the plastic with some rustoleum black textured paint. As soon as the paint hit the plastic, I heard loud cracks, looked down, and saw that some of the thinner cracking I had repaired was now re-cracked!!! I don’t know if there was a chemical reaction between the paint and plast-aid, or if the cold aerosol spray reacted with the plastic, or what, but the point is, it cracked.
Assuming you used Rustoleum Stops Rust Textured Black paint from a spray can it contains 50% acetone and that would have directly attacked the methyl methylacrylate that is the monomer used to fuse the powder in Plast-Aid. That's my theory at least.
Well shiiiiit.
I see you're still living up to your member title.
  • Upvote 1
3 hours ago, Oreo931 said:
Well shiiiiit.
Among the many other categories we sell into, my company manufactures all of the products under the Permatex brand (direct competitors to Loctite and Plast-Aid and JB Weld).  I talk with chemists about these kinds of issues on a regular basis. Your assumption is right, if you had used a water based paint with a roller or air gun you likely wouldn't have run into that issue.
Thanks for the write-up, I appreciate the insights you shared around the specifics for reinforcing the upper mount points.
  • 1 year later...
Thanks for the write-up @Oreo931. Do you still have the photos for this somewhere? I'm about to repair my dash, and the photos would be useful.
I'll text him about this for you... I think he will still have the photos. This is a DIY we all need to do lol
The pics are still there. I don't have the time to rehost them. You can get around the photobucket block by installing a plugin on chrome. I use this one: https://chrome.google.com/webstore/detail/photobucket-hotlink-fix/kegnjbncdcliihbemealioapbifiaedg?hl=en
Alternatively, you can view the entire album of dash repair pics here: http://s104.photobucket.com/user/iamawass/library/Dash Repair
  • Upvote 2
  • 2 weeks later...
Posted (edited)
I did the Chrome plugin thing (pretty cool, did not know it existed) and printed page 1 to pdf with all the images. Here it is if anyone else is interested. Thanks for the great write-up. I had forgotten about this one.
Direct link: Volospeed_-_850_Dash_Repair.pdf
Dropbox Link: Volospeed_-_850_Dash_Repair.pdf - Dropbox
Edited by JA VOLVO
Added Dropbox link
  • Upvote 3
  • 3 weeks later...
If you fellas are using chrome, then I recommend downloading "Photobucket Hotlink Fix" extension to make all these old photobucket forum threads work again.
  • Upvote 2
Guest
Reply to this topic...
  Only 75 emoji are allowed.
