What's the Compression like on Your Turbo 5 Volvo?
grasshopperR
Compression
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Every time I look up a Volvo compression test, it's always the people with horrible compression (90-125). I was wondering what VS has on their cars. Hopefully better!
Edit: including mileage in a post would be nice
If I remember right 185 is considered new, and 150 is the lower end where it starts to go become concerning. I remember doing it on a 100k engine that went another 100k and I believe at the time I was mostly getting in the mid 150's. Not all gauges read the same - precision varies.
Rule of thumb is that uniformity is more important. That's because unless the car has crazy high mileage, you're not expecting all 5 cylinders to fail simultaneously. and uniformly. So if you see 140-140-140-90-140, you've got a problem, but it isn't the 140's. If you're getting uniform but low numbers, I'd probably get another gauge to confirm.
I did 2 tests so far, one test showed I was in the 155-165 area and one faulty gauge wouldn't show anything above 60 psi. So, I don't know for sure completely.
  • 2 weeks later...
I was pleasantly surprised by 180-190 across all my cylinders at 115k. Though I think lpts would be on the higher side.
After replacing my cylinder head last summer (worn valve stem seals were leaking oil into the exhaust, no effect on combustion/compression) I tested mine with a rented gauge from Autozone, so I can't speak to the absolute accuracy of the gauge, but all 5 cylinders were between 165 and 170.
I was pretty happy with those numbers - for a motor with ~185k on it at the time to exhibit less than 5% variation across all 5 cylinders seemed pretty good to me.
  • 3 weeks later...
  • 2 months later...
On 3/10/2017 at 11:10 AM, MattyXXL said:
131k fresh rebuild just over 1k ago 190 across the bar wet
What's the dry test number? Wet test is usually used to diagnosis a problem.
