TheOtherWhiteMeat Posted November 28, 2017 Report Posted November 28, 2017 A truly unique and one of a kind Volvo S80. One of only a handful in the world to be taken to the next level. The car has been shown in WA and OR at numerous events and featured online a number of times. I am the second owner of the car, and have owned it since 2009. It has been meticulously cared for its whole life, never smoked in and has always been serviced at Sandberg Northwest Volvo in Lynnwood, WA where it was purchased new for $47k. The engine and drivetrain are in perfect working order with no leaks, grime or strange noises. You could eat off of the top and the bottom of the engine. Amsoil 10W40 motor oil and Volvo OE oil filters have been used since I've owned the car. The engine was compression tested recently and tested perfectly with even and strong pressure in all cylinders. New transmission, rear main seal, cam tray and cam seals, new timing belt, new transaxles, new oxygen sensors (all 4), recently new OEM Volvo coil packs (all 6), new steering rack and tie rod ends, recently new radiator and hoses, recent ceramic brake pads, Powerstop slotted rotors with black Brembo caliper covers. 20x10 TSW Zolder wheels wrapped in Nitto Neo-Gen tires with 80% tread life remaining. (Awesome rain performance) This is the Volvo flagship luxury sedan and has every option available including dual climate control, 8 way power heated seats and mirrors, safety lighting, 4-speed automatic Geartronic transmission w/OD, traction control, power moonroof, tilt/telescopic steering wheel, security system and 9 speaker AM/FM/CD Dynaudio sound system. Many unique upgrades and detailed features throughout the car including: Painted and body matched engine top cover and intake manifold Body color matched moldings and skirting Fenders and quarters rolled to provide a wider stanced appearance Custom poly front lip spoiler Custom fiberglass eyebrows 15% Suntek carbon-dyed window film 5000K 55W HID lighting in 2006 S80 headlight housings with LED city lights 5000K 55W HID lighting in custom OEM fog light housings Brushed aluminum vinyl wrapped interior trim Aluminum gauge cluster trim rings imported from Sweden Custom 2.5" dual exhaust with Magnaflow muffler and polished tips K&N high flow air filter KW V2 adjustable coilovers with new strut mounts and Eibach rear coil springs iPd poly upper engine mount iPd heavy duty sway bar endlinks iPd poly subframe bushing stabilizer inserts Car is located in Seattle. $6,500 obo
TheOtherWhiteMeat Posted February 9, 2018 Author Report Posted February 9, 2018 A bump for a lower price
Guest Nice S80 Posted February 18, 2018 Report Posted February 18, 2018 Hello. I have seen your car over and over again thru my researching in the WWW. Im curious about the eyebrows. Do you made them yourself? Is it possible to buy these off you? I would really appreciate it if you gimme a quick feedback. K6z6.mm@gmail.com Greetings from Germany Michael Meyer
