goobernoodles Posted December 3, 2017 Report Share Posted December 3, 2017 Not there, but the light at the end of the tunnel is approaching. Huge thanks to @Tightmopedman9 for not blowing up my motor on a difficult tune. Time for a stronger wastegate. Link to comment Share on other sites More sharing options...
Tightmopedman9 Posted December 3, 2017 Report Share Posted December 3, 2017 Phil, you should post up some shots of that gorgeous engine bay! Some notes about Phil's setup: GTX3071R with .63 A/R, ATP 'ultimate' internal wastegate, screamer pipe and a 14psi wastegate actuator 139.5mm forged rods, Wiseco pistons, 8.5:1 compression ratio Pump gas, 92 (RON+MON)/2, no WMI 3.75" OD MAF housing Snabb generation 1 FMIC Deatschwerks 72lb/min (760cc) injectors IGN-1A ignition coils NGK BKR7E spark plugs Stock head, stock cams, stock intake manifold, 'R' exhaust manifold We had problems keeping the boost consistent throughout the RPM range. As soon as the TCV duty cycle dropped below 99% nd allowed the wastegate to open it wouldn't be able to fully close again. I struggled with keeping it fully shut as high into the RPMs as possible, without a taper to the target TCV duty cycle, but this made it very difficult to avoid overshoot. We tried increasing the wastegate preload, but this helped only marginally. Sometime in the spring Phil will probably add water methanol injection and a stronger wastegate actuator, at which point we'll re-tune the car. We were able to get 451wtq at 4400RPM, but had to end the run prematurely due to boost overshoot and knock. Highest HP occurred on the same run at 384whp. I believe that with a properly functioning wastegate we could see 450whp/450wtq. The .63A/R turbine housing is very responsive. It can make 20psi at 3700RPM and 30psi at 4200RPM. Link to comment Share on other sites More sharing options...
apeacock Posted December 3, 2017 Report Share Posted December 3, 2017 Love the front end lift. Link to comment Share on other sites More sharing options...
goobernoodles Posted December 4, 2017 Author Report Share Posted December 4, 2017 Link to comment Share on other sites More sharing options...
TryingBe Posted December 4, 2017 Report Share Posted December 4, 2017 Nice power. How much boost do you run on the street to have traction in 2nd gear? Link to comment Share on other sites More sharing options...
gmsgltr Posted December 5, 2017 Report Share Posted December 5, 2017 Wow great work guys - true sleeper! Link to comment Share on other sites More sharing options...
Commander Riker Posted December 5, 2017 Report Share Posted December 5, 2017 Took me a second to find that 5th coil pack. Nice. Link to comment Share on other sites More sharing options...
BlackT5 Posted December 6, 2017 Report Share Posted December 6, 2017 Nice work Aaron! I miss my .63 responsiveness Link to comment Share on other sites More sharing options...
BlackT5 Posted December 6, 2017 Report Share Posted December 6, 2017 What boost level and fuel pump? Link to comment Share on other sites More sharing options...
Brad850 Posted February 5, 2018 Report Share Posted February 5, 2018 I just bought the same turbo. Your car is exactly where I want mine to be! Also do you have any more pictures of your intake setup, specifically closer to the turbo inlet? I'd like to see what you did there. Link to comment Share on other sites More sharing options...
German850R Posted February 9, 2018 Report Share Posted February 9, 2018 Love the hardlines to the turbo. Are these stainless 10mm lines? Link to comment Share on other sites More sharing options...
gmsgltr Posted February 12, 2018 Report Share Posted February 12, 2018 Did you re-locate the battery to the trunk? Where did you route the lines, under the car or under the carpet etc? Link to comment Share on other sites More sharing options...
bob82pigdog Posted February 19, 2018 Report Share Posted February 19, 2018 I want to see more. Love this set up! Link to comment Share on other sites More sharing options...
Mesoam Posted February 21, 2018 Report Share Posted February 21, 2018 any reason for not going external WG? nice work Link to comment Share on other sites More sharing options...
