galexie64 Posted March 14, 2018 Author Report Share Posted March 14, 2018 I hit 190k. Not the best picture because I took it last night and I need to get better LED bulbs for that light. Link to comment Share on other sites More sharing options...
galexie64 Posted March 19, 2018 Author Report Share Posted March 19, 2018 I decided to tackle a big job this past weekend. The full interior color change. I didn't complete everything but I did get most of it done. The dash, carpet, front seats, the trim from the rear seats forward, rear seat bottoms, and the center console. I still need to do some of the rear trim, the rear seat backs, three door panels and the rear carpet. The door panels need to be re-glued before the install. I took my time on this because I wanted to do it right one time. I cleaned everything before the install. I also repaired the heating system so I'm not stuck on defrost. It turns out that my problem was a Lego piece inside the heat duct jamming one of the flaps but I went ahead and replaced the actuator to be sure. Before: After: Link to comment Share on other sites More sharing options...
Andzey Posted March 21, 2018 Report Share Posted March 21, 2018 Dont wannabe a blasphemer but your R deserves a manual swap Link to comment Share on other sites More sharing options...
galexie64 Posted March 21, 2018 Author Report Share Posted March 21, 2018 6 hours ago, Andzey said: Dont wannabe a blasphemer but your R deserves a manual swap I like manual cars but I have no plans to do that on this car because my wife can't drive a manual. I have my Mazda for when I want to drive a manual. Link to comment Share on other sites More sharing options...
galexie64 Posted April 11, 2018 Author Report Share Posted April 11, 2018 My parts came in early, I got them on Saturday. Now I need to find the time to install them. Front Wheel Hub Assemblies - FAG 274378 Sway Bar Link - Meyle HD 31212730 Transfer Case Input Shaft Seal - Genuine Volvo 30735126 Fuel Pump Tank Seal - Genuine Volvo 9447179 Drive Axle Seal - Genuine Volvo 9143885 Turbocharger Oil Line Gasket Lower - Genuine Volvo 31251439 Turbocharger Oil Line Gasket - Genuine Volvo 31251456OE Radiator - Nissens 8601356 Spark Plug Set - Genuine Volvo 8692071 I did find the time to get the rest of my back seat swapped out. I also sold a bunch of parts so I can get more parts for the car. Also I ordered a Snabb Reverse Intercooler Piping kit in black with big bore throttle body tube and the Snabb Upper Idle Air Hose in black. Link to comment Share on other sites More sharing options...
galexie64 Posted May 14, 2018 Author Report Share Posted May 14, 2018 So my really small coolant leak turned into leaving a puddle under the radiator. I parked the car for the week and will be driving my Mazda until I can get around to finishing up the repairs. The list of retairs: -replace the radiator -turbo drain line seals -tranny to angle gear seals -passenger side front wheel bearing -fuel pump tank seal -spark plugs "Fun" stuff: -Snabb RIP kit -Snabb fresh-air pipe -silicon vacuum lines -SAS delete -tuning I have a laptop setup for tuning and I have everything I need to add the switch to the old AWD ECU. I will get pictures posted of everything soon. I need to get a wideband and a 3" downpipe to complete my plans for the car. Link to comment Share on other sites More sharing options...
