mrtl321 Posted April 30, 2019 Report Share Posted April 30, 2019 Wondered if anyone knew the software/part number to disable the drl's on a 2007 s80 v8. Took it in to the dealership but the part/software number I found didnt do the trick. (30679690) Thanks! Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 30, 2019 Report Share Posted April 30, 2019 Post the VIN please Link to comment Share on other sites More sharing options...
mrtl321 Posted April 30, 2019 Author Report Share Posted April 30, 2019 YV1AH852771044369 Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 1, 2019 Report Share Posted May 1, 2019 This car has active bi-xenons, but does not have an auto headlight switch. You should be able to go to car menu > light settings > daytime running lights and turn it off there. You will still have to manually move the switch back and forth to turn the headlights on and off if you select this option. Link to comment Share on other sites More sharing options...
mrtl321 Posted May 1, 2019 Author Report Share Posted May 1, 2019 Sadly there isnt that option within the car menu. There is a software update out there but didnt know the number so they could load it in and disable the daytime running lights. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 1, 2019 Report Share Posted May 1, 2019 Attached are screen shots of all the software packages available for your car. This isn't totally the gospel since the vehicle isn't connected, but pretty damn close. If I'm guessing they might need to try headlight application 2 or 3, but I can't see much without the car connected. Link to comment Share on other sites More sharing options...
mrtl321 Posted May 1, 2019 Author Report Share Posted May 1, 2019 This is an amazing list!! Thank you! Link to comment Share on other sites More sharing options...
