Put this reference info on SS, figured it's more relevant on here
Note that the vin break listed, even in the '99 slide is a '98 vin break.
mid 98-99 style
longer pinion to diff casing offset, recessed yoke for CV joint (unlike early '98)
'00 ONLY
note the shorter pinion to diff casing offset
Note 1 : 9183491 shaft = chassis range S70 465739-621367 V70 465339-630091
9463300 shaft = chassis S70 621368 - on V70 630092
The production change here was in regard to the center bearing - later shafts have a larger bearing & carrier.
Note 2 pertains to the fact that the replacement CV ONLY fits original Prop shafts
Driveshafts - mid 98 - 00
Carrier variations
Torque Tube/ VC variations
mid '98-'99 BG length
'00 BG length
change in sump design
BG internal components
Difference in '98-99 & '00 Pinion - '00 uses Koyo bearings, smaller OD
Diff/BG coupler
check for spline wear here:
Inside Viscous Coupler
Freewheel Mechanism
Typical torn front CV boot
Binding CV due to lack of grease/cooked - typical cause of vibration
CV components
Re-assembled, ready for CV grease - note markings to ensure correct reassembly
  • Replies 35
Wow. Thanks Hussein!
So what happened to this coupling? I'm guessing they aren't meant to be solid with black crud like that and those little tabs are individual wet clutch type disks.
Half the discs are connected to the front shaft, the other half are tied to the rear section (alternating) - there was a silicone base fluid in there, as the discs slip the fluid heats up & progressively locks the discs together, transferring power to the rear.
The failure of this unit was the freewheel mechanism - one of the bearings let loose from it's ramp, and rattled around like a tin can. No way to fix them.
  • 1 month later...
is there any way to change the center bearing of the driveshaft as viewed in the picture with the 3 driveshafts.. even vadis has no part number, and mines worn out due to a "temp fix" that ive been running for a year..
There are sold - however, I don't know how you could get the yoke off to do it, never tried. I think I'd just go reman from coloradodriveshaft at that point - the carrier w/bearing is a couple hundred......
its more the rubber that i need. can that be changed, if i have to rebuild, i'll just wait for the CV joint to break and do it all at once.
No way to do the rubber alone
Link
  • 3 weeks later...
^ Thanks. Just trying to help anyone looking for differences when sourcing parts or contemplating a manual conversion
Right Axle Variants '98-00
'98-'00 front to back. Arrow indicates seal seat (28mm OD).
So, the '00 axle doesn't work in an M66 AWD because it's too short. Fixed point is the bearing, since that is located on the engine in the same location regardless of transmission. This is from a 5 speed Auto AWD ®. If there were any 4 speed Auto AWD in '00, I would expect that it would work as is. The '99 axle will work, but the outer BG seal seat is not in the correct location.
Either a .5mm collar needs to be fabricated for the seal to seat (1mm difference in OD between seal seat & rest of shaft), or a smaller ID (27mm) seal would need to be sourced. Probably easier to look for a seal, IMO
28mm ID
38mm OD
Shaft OD
27mm
Do you have an axle from a 00 AWD or XC to compare to the 00 R axle?
Those still retained the 4 speed auto's, the only AWD model to get the 5 speed was the 00 R.
Also, this is a great thread, thanks for organizing all this info!
The last two '00 XC's I have worked on were both 5 speeds - I haven't seen a '00 with a 4 speed for comparison.
There are 2 right axles listed for '00:
8251521 (8601580)
8251523 (8601589) this one says '00-, so perhaps the 521 is '00 4 speed auto, which should be a direct fit for the M66 AWD, but I'd need to see one to determine that.
Hm interesting. The "model specifications" list on SS says 00 XCs still had the 4 speed, but it appears that that listing is mistaken. Looking at all the 00 XCs for sale right now, they all have 5 speed auto transmissions.
Just checked further, the The original part number for '00 5 speed AWD axle is 9463921. This number supercedes to this exchange # 8251521 (8601580), so perhaps the 8251523 (8601589) is for the 4 speed. All speculation, without an axle to compare
