JHEIII874T5M Posted March 20, 2005 Author Report Share Posted March 20, 2005 is it hitting what the red arrow is pointing at?←Yes, it is hitting where the red arrow is pointing at. However, as I start to grind that down, down, down, I get to the point where I'm grinding the ridge farther down than the top of the bolt, and grinding down a bolt that size is just stupid . Thus, I'm at a loss. I figure, cut my losses now, just sell the wastegate and turbo... at least get $600 from those two items, get my suspension installed, and work on other areas of the car that need help more desperately than a bigger turbo on stock chip... sometimes you just have to face the music :( Link to comment Share on other sites More sharing options...
ROB @ VMS Posted March 20, 2005 Report Share Posted March 20, 2005 Dont give up. None of my parts fit right in . You will figure out something im sure. Link to comment Share on other sites More sharing options...
turbor850 Posted March 20, 2005 Report Share Posted March 20, 2005 Dont give up. None of my parts fit right in . You will figure out something im sure.←how much did that manifold cost Rob ? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 20, 2005 Author Report Share Posted March 20, 2005 I did figure something out, ported conical outlet 15g has made 260 whp on my car with a crappy tune, I can make 290 whp out of a solid tune straight outlet full 3" 15G and then spray a 75 shot, all solved. Link to comment Share on other sites More sharing options...
Guest DougK Posted March 20, 2005 Report Share Posted March 20, 2005 Joe take some pictures. I'll do some thinking for you. If theres someone here who's BTDT and beat square pegs into round holes here its me.Your far from the first person to run a hybrid on a 850. Im sure theres a solution staring you in the face... just to tired/angry to see it. Been there plenty of times before. Link to comment Share on other sites More sharing options...
WhiteT5 Posted March 21, 2005 Report Share Posted March 21, 2005 Hey, I bet there's been at least 1 guy who has run that turbo setup over in Sweden. If you want, transcribe what you want me to say and I'll translate it and post it over in the boards on Turbo Performance Club. Link to comment Share on other sites More sharing options...
turbor850 Posted March 21, 2005 Report Share Posted March 21, 2005 Hey, I bet there's been at least 1 guy who has run that turbo setup over in Sweden. If you want, transcribe what you want me to say and I'll translate it and post it over in the boards on Turbo Performance Club.←Why don't you say when working with stock manifold and having to put a larger turbocharger on, say T3/T4, how do you get around the motor mount without having to get a new manifold. Ask them if a spacer would do the trick, modify the motor mount, etc. ? Link to comment Share on other sites More sharing options...
EricF Posted March 21, 2005 Report Share Posted March 21, 2005 I did it on my car, and it was fine. I also had a bigger compressor housing by a pretty good deal. Erik Bergum and a couple others have T3/T04E's as well... But for whatever reason, it does not fit on Joseph's car.My setup had no interference from the mount whatsoever. Link to comment Share on other sites More sharing options...
turbor850 Posted March 21, 2005 Report Share Posted March 21, 2005 I did it on my car, and it was fine. I also had a bigger compressor housing by a pretty good deal. Erik Bergum and a couple others have T3/T04E's as well... But for whatever reason, it does not fit on Joseph's car.My setup had no interference from the mount whatsoever.←do you have any pictures of it ?good ones ? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted March 21, 2005 Author Report Share Posted March 21, 2005 no picture, but Eric came over and he agreed with me when I said screw it, it won't fit. Link to comment Share on other sites More sharing options...
turbor850 Posted March 21, 2005 Report Share Posted March 21, 2005 no picture, but Eric came over and he agreed with me when I said screw it, it won't fit.←whats the difference between yours and Erics ? Link to comment Share on other sites More sharing options...
Guest DougK Posted March 21, 2005 Report Share Posted March 21, 2005 no picture, but Eric came over and he agreed with me when I said screw it, it won't fit.←have you tried using Erics motor mount brackets Link to comment Share on other sites More sharing options...
turbor850 Posted March 21, 2005 Report Share Posted March 21, 2005 ooooooooooooooooooooooooooooooohhhhhhhme and Sean, mostly sean, actually all seansaid this, i asked if manifold are different"Aha! The exhaust manifold is different from model year '96 and on. The part # for '96 and newer is 1270537. For '94 and '95 it's 1366689."thats what he said, so, now why are the manifolds different after 96 and up ?maybe thats why Joe and my turbo aren't fitting . . .hmmmmmm <_< Link to comment Share on other sites More sharing options...
550 Posted March 21, 2005 Report Share Posted March 21, 2005 that means new mani time well old mani Link to comment Share on other sites More sharing options...
turbor850 Posted March 21, 2005 Report Share Posted March 21, 2005 that means new mani time well old mani←maybe but it still doesn't make sense . . . . Link to comment Share on other sites More sharing options...
