Nativeman23 Posted July 29, 2009 Report Share Posted July 29, 2009 Hello all I just installed mine, when i find the cable for my camera i will put up some pics, i left the stock solenoid hooked up up stream of the boost controller, it doesn't affect it. I used the forge motor sports unos boost controller from www.horsepowerfreaks.com I have had no problems from it, but just intalling it inline fresh out the box pushed my engine to 10psi. no other mods right now besides the boost gauge. I was able to do 12lbs easy not trying for more till i get an intake. Link to comment Share on other sites More sharing options...
Nativeman23 Posted July 29, 2009 Report Share Posted July 29, 2009 ea,the top line there is your compressor(red line) A\and the one you have loose is the waste gate(yellow)donut, I would not run more than 12lbs, mostly for the fuel pump the injectors can take it as the stock injectors on the s40 are 420cc but I don't know about the fuel pump itself. Link to comment Share on other sites More sharing options...
Odin2347 Posted August 2, 2009 Report Share Posted August 2, 2009 hey purchased a NXS MBC off amazon a few days ago for my s40 1.9t and went about putting it in today with the instructions from the first page. Not sure if I did it right. Don't have a boost gauge yet so hard to judge the boost i'm getting. Here's a picture also wondering if zip ties are good enough to hold the hose in? I notice when I step off the gas a sound of air being pushed out. Not sure where this is coming fromthanks Link to comment Share on other sites More sharing options...
R11CKSO Posted August 2, 2009 Report Share Posted August 2, 2009 you should bypass the boost control solenoid, is better this way, you'll get more stable boost and is waaaaaay better check the other How-to it tells exactly how to do it, and one advice man always put a gauge before you twist your MBC because if you overboost you might be running lean and damage seriously your car you can get one for like 10 bucks and its very easy to fit... also that way you can know if you have leaks as well... Link to comment Share on other sites More sharing options...
R11CKSO Posted August 2, 2009 Report Share Posted August 2, 2009 you should bypass the boost control solenoid, is better this way, you'll get more stable boost and is waaaaaay better check the other How-to it tells exactly how to do it If I remember right it's a video actually, and one advice man always put a gauge before you twist your MBC because if you overboost you might be running lean and damage seriously your car you can get one for like 10 bucks and its very easy to fit... also that way you can know if you have leaks as well... Link to comment Share on other sites More sharing options...
Appleyard Posted May 15, 2011 Report Share Posted May 15, 2011 hey guys, i just installed my hallman rx boost controller exactly how it was shown in this how-to. I have turned to the max and the highest my boost got to was 12.5 psi. i cant seem to get higher than this for some reason. can anyone help me out?? Link to comment Share on other sites More sharing options...
theForgottenone Posted May 15, 2011 Report Share Posted May 15, 2011 Adjust your wastegate. Link to comment Share on other sites More sharing options...
daveherz827 Posted May 15, 2011 Report Share Posted May 15, 2011 Anyone got the links for either bypassing the bcs or adjusting waistgate.. If not the link for bcs at least let me know which way to turn the nut on the arm Hahahaha Link to comment Share on other sites More sharing options...
theForgottenone Posted May 15, 2011 Report Share Posted May 15, 2011 Less thread showing on the nut is tighten = hold more boost. Link to comment Share on other sites More sharing options...
Appleyard Posted May 15, 2011 Report Share Posted May 15, 2011 i thought i wouldnt have to adjust the wastegate, since the hallman mbc states it can increase boost up to 30psi ... is the arm on the wastegate easy to get to? Link to comment Share on other sites More sharing options...
arrtchiu Posted May 15, 2011 Report Share Posted May 15, 2011 It is easy to get to.Remove heat shields.Remove retaining pin holding wastegate arm. Remove 2 bolts holding wastegate to compressor housing.Remove wastegate. Adjust arm.Reattach. MBC might hold 30psi but your turbo can't produce that... Link to comment Share on other sites More sharing options...
daveherz827 Posted May 15, 2011 Report Share Posted May 15, 2011 Now are we tightening it? Making it held slightly open? Or are we trying to show more threads? I've always questioned how to do this Link to comment Share on other sites More sharing options...
Appleyard Posted May 16, 2011 Report Share Posted May 16, 2011 MBC might hold 30psi but your turbo can't produce that...oh i know, i was just saying that the MBC can do that and i know others on here produce more than 12.5psi with the 12T which makes me think that something might be off about my set up. but im not sure on what it could be Link to comment Share on other sites More sharing options...
arrtchiu Posted May 16, 2011 Report Share Posted May 16, 2011 Now are we tightening it? Making it held slightly open? Or are we trying to show more threads? I've always questioned how to do thisLess threads showing means the wastegate actuator has to push further to open the wastegate.Further it has to push to open = more boost needed to open = holds more boost.oh i know, i was just saying that the MBC can do that and i know others on here produce more than 12.5psi with the 12T which makes me think that something might be off about my set up. but im not sure on what it could bePossibilities:- Wastegate needs adjusting (as xcites40 suggested)- Bypass valve ("BOV") leaking- Some other boost leak- Damaged turbo- Exhaust leak before turbo- Clogged cat causing exhaust backpressureMost likely one of the first two. Link to comment Share on other sites More sharing options...
