EricF Posted March 30, 2005 Author Report Share Posted March 30, 2005 Well, honestly the T3 is the easiest to find option. You just need a T3 from a ford T-bird or 2.3 Mustang. There's one on e-bay now that's pretty cheap that I may buy, it could be here for sale shortly as a bolt-on kit As far as fueling concerns, I'd just see if you can get a 16T or 18T map from a chip maker. Stock injectors oughta be fine... The 60 trim is on par with a 16T, flow-wise... Could be a little more, but I'm not really sure. Link to comment Share on other sites More sharing options...
Guest DougK Posted March 30, 2005 Report Share Posted March 30, 2005 Well, honestly the T3 is the easiest to find option. You just need a T3 from a ford T-bird or 2.3 Mustang. There's one on e-bay now that's pretty cheap that I may buy, it could be here for sale shortly as a bolt-on kit As far as fueling concerns, I'd just see if you can get a 16T or 18T map from a chip maker. Stock injectors oughta be fine... The 60 trim is on par with a 16T, flow-wise... Could be a little more, but I'm not really sure.←It will only be a true "bolt on" if you use a volvo exhaust housing.The down pipe will not work either. Link to comment Share on other sites More sharing options...
orange850t Posted March 30, 2005 Report Share Posted March 30, 2005 Like I said before I am interested. Sounds like a 17psi speedtuning chip would be a nice start. Doug can you MS a 5cyl? Link to comment Share on other sites More sharing options...
EricF Posted March 30, 2005 Author Report Share Posted March 30, 2005 It will only be a true "bolt on" if you use a volvo exhaust housing.The down pipe will not work either.←If I do this, I plan on cannibalizing Isaac's half of a Volvo T3 he left in my garage... Which happens to include a Volvo wastegate housing. It would be the .48 A/R turbine housing but would work fine I think... Not as good as a .63 A/R, but it's easy enough to upgrade if it doesn't flow quite enough to be real good.With the Volvo turbine housing and wastegate housing, it really should be a direct bolt on except the oil drain and possibly the feed (think it's the same thread though). Link to comment Share on other sites More sharing options...
Guest DougK Posted March 30, 2005 Report Share Posted March 30, 2005 The .48 a/r would probably be ideal with a 60trim on a Auto car Link to comment Share on other sites More sharing options...
orange850t Posted March 30, 2005 Report Share Posted March 30, 2005 I searched, have you figured out if you can use the cps to trigger spark? Link to comment Share on other sites More sharing options...
PullMyFinger Posted March 31, 2005 Report Share Posted March 31, 2005 I PM'd you Eric, lets get the ball rolling.And thanks for all the input guys! This should be a lot of fun for me. Link to comment Share on other sites More sharing options...
orange850t Posted March 31, 2005 Report Share Posted March 31, 2005 Let me know if you find anothe frankenturbo Eric....like I said I'm game to play as well. Link to comment Share on other sites More sharing options...
