Abs Unit Out What Now
  • 1 year later...
I really need to investigate with more time with mine. I didn't see any cracks. It's all conformally coated. You can open it with out cutting, you have to press the holding clips in the opposite direction, i used a small wratchet socket with a hammer to do that. The cover then popps off with minimal force.
I did take a picture of it. however again i'm hard pressed to find these cracks on my own. I proberly won't get it repaired till I really need a new one when i'm done with it.
is that the connector on the right side? where i should be looking for. i'm guessing these are hair line cracks?
does the circuit card come out of this housing?
thanks
Drew
  • 1 year later...
Bumping this topic. Opened up a bad ABS module and this what I found. I didn't just find cracked solder on the two power prongs, but also on the data connector, 9 pins were cracked on this side and the two power prongs were as well. I'll be doing a write up on the repair, but these pics will show you what to look for.
