torpis Posted June 26, 2009 Report Share Posted June 26, 2009 Sute wrote on Thu, 25 June 2009 23:01torpis wrote on Thu, 25 June 2009 06:10Sute wrote on Thu, 25 June 2009 03:12Is N/A ph2 head with mechanical lifters? Yes 2000-> mech = goodYeah! What about the valve size then? Diameter in / out? All heads have the same size exhaustvalve, one of the N/A heads has larger 32mm inletvalves. A turbo engine has 30x7x104.10mm inletvalve and a tiny 27x7x103.30mm outlet valve. I upgraded to 33mm in and 30.5mm out on my head. The stock exhaustvalve is large enough for big power, but changing it to a larger size ofcause it flows better which means you can reduce the duration of the exhaust camshaft making the overlap/blow by minimal which is good for an all around engine. Remember that all of us still wants to use the engine in a car used on road and not for pure racing.also remember the ph2 heads uses a 6mm shaft valve which makes it flow better and reduces weight...and durability...stock ph2 springs are a joke. even if you know nothing about engines these are suprisingly soft. the ph1 springs are what you can expect a spring valve to be... my dual upgraded springs are HARD. I guess too hard for the 6mm shafts, so I came up with a softer dual spring setup sutable for my aluminum retainers and the ph2 head/vavle assembly. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted June 26, 2009 Report Share Posted June 26, 2009 torpis wrote on Fri, 26 June 2009 00:31Sute wrote on Thu, 25 June 2009 23:01torpis wrote on Thu, 25 June 2009 06:10Sute wrote on Thu, 25 June 2009 03:12Is N/A ph2 head with mechanical lifters? Yes 2000-> mech = goodYeah! What about the valve size then? Diameter in / out? All heads have the same size exhaustvalve, one of the N/A heads has larger 32mm inletvalves. A turbo engine has 30x7x104.10mm inletvalve and a tiny 27x7x103.30mm outlet valve. I upgraded to 33mm in and 30.5mm out on my head. The stock exhaustvalve is large enough for big power, but changing it to a larger size ofcause it flows better which means you can reduce the duration of the exhaust camshaft making the overlap/blow by minimal which is good for an all around engine. Remember that all of us still wants to use the engine in a car used on road and not for pure racing.also remember the ph2 heads uses a 6mm shaft valve which makes it flow better and reduces weight...and durability...stock ph2 springs are a joke. even if you know nothing about engines these are suprisingly soft. the ph1 springs are what you can expect a spring valve to be... my dual upgraded springs are HARD. I guess too hard for the 6mm shafts, so I came up with a softer dual spring setup sutable for my aluminum retainers and the ph2 head/vavle assembly.And this is same with 1.6, 1.8 and 2.0 litre ph2 N/A engine? Link to comment Share on other sites More sharing options...
torpis Posted June 26, 2009 Report Share Posted June 26, 2009 Sute wrote on Fri, 26 June 2009 01:23And this is same with 1.6, 1.8 and 2.0 litre ph2 N/A engine? one of the ph2 N/A heads has the larger 32mm valve (make a wild guess which one) and *the others have the 30mm valve.*from what I know of. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted June 26, 2009 Report Share Posted June 26, 2009 torpis wrote on Fri, 26 June 2009 02:41Sute wrote on Fri, 26 June 2009 01:23And this is same with 1.6, 1.8 and 2.0 litre ph2 N/A engine? one of the ph2 N/A heads has the larger 32mm valve (make a wild guess which one) and *the others have the 30mm valve.*from what I know of.B4204S...? Link to comment Share on other sites More sharing options...
torpis Posted June 26, 2009 Report Share Posted June 26, 2009 Sute wrote on Fri, 26 June 2009 03:15torpis wrote on Fri, 26 June 2009 02:41Sute wrote on Fri, 26 June 2009 01:23And this is same with 1.6, 1.8 and 2.0 litre ph2 N/A engine? one of the ph2 N/A heads has the larger 32mm valve (make a wild guess which one) and *the others have the 30mm valve.*from what I know of.B4204S...?man come on, ph2 2.0 litre N/A Link to comment Share on other sites More sharing options...
Sute1568908560 Posted June 26, 2009 Report Share Posted June 26, 2009 torpis wrote on Fri, 26 June 2009 03:51Sute wrote on Fri, 26 June 2009 03:15torpis wrote on Fri, 26 June 2009 02:41Sute wrote on Fri, 26 June 2009 01:23And this is same with 1.6, 1.8 and 2.0 litre ph2 N/A engine? one of the ph2 N/A heads has the larger 32mm valve (make a wild guess which one) and *the others have the 30mm valve.*from what I know of.B4204S...?man come on, ph2 2.0 litre N/AYes, I will come... What about compression ratio, any difference with that? Link to comment Share on other sites More sharing options...
tcode1568908558 Posted July 11, 2009 Author Report Share Posted July 11, 2009 Afer a few tweaks into the VEMS, engine needed more fuel. Ended up with a bit over 80% DC of injectors.According to the fuel calculator http://www.witchhunter.com/injectorcalc1.php4 having additional few more HP's .Also bought a nice Pioneer double din HU: Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 13, 2009 Author Report Share Posted December 13, 2009 Link to comment Share on other sites More sharing options...
benisohh Posted December 13, 2009 Report Share Posted December 13, 2009 tcode wrote on Sun, 13 December 2009 10:38That looks pretty awesome! Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 13, 2009 Author Report Share Posted December 13, 2009 Thanks . Here's another cool one. Link to comment Share on other sites More sharing options...
benisohh Posted December 14, 2009 Report Share Posted December 14, 2009 Hey tcode, whats your plan for the empty space in your dash where your cup holder was? I am brainstorming of what to put there, and I think a gauge wouldn't work, and I have no other clue what to put in it! Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 14, 2009 Author Report Share Posted December 14, 2009 Will put Clarion 2 din HU with 6 disc MP3/WMA changer , it's not a direct fit so I'll definitely have fiberglass job to do. And when messing with fiberglass, why not "put" the unit up as much as possible.Btw. the unit is OEM Subaru Impreza MY08/09. Got it for a $70, been in the previous owner car for less than 2 weeks .I missed rotary controls and don't really need that big screen, so I sold Pioneer DVD unit. Link to comment Share on other sites More sharing options...
benisohh Posted December 14, 2009 Report Share Posted December 14, 2009 hmm, yea I've gotten the Pioneer AVH p31000DVD for a present-xmas. And I plan on installing it once I get it. I thought about just restarting the dash and putting it in the center, but I'd have to rework the rest of it, and not sure I'm willing to do that. (My fiberglassing skills aren't up to par)Post pics when you have it completed, I am really interested as to what she'll look like! Link to comment Share on other sites More sharing options...
tcode1568908558 Posted December 14, 2009 Author Report Share Posted December 14, 2009 Sure I will post pics. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted January 2, 2010 Author Report Share Posted January 2, 2010 Link to comment Share on other sites More sharing options...
