Volvo S40 T4 with Holset for 2011 season!!!
Current project 2009-2010. Hardware installed and tune coming with bigger injectors in this spring 2010 with summer tires. Winter tires now on and icy roads. Smile Goal with 1.6bar 350hp with stock EMS2000. Now using only 1.2bar and 300hp.
Volvo S40 T4 1998 (B4194T):
-Masterpower 810023-063 turbo (44 lb/min flow)(Same size as GT3071 T3 0.63A/R) http://i119.photobucket.com/albums/o143/VulvaS40T4/MasterPow er810023.jpg
-V-band internal wastegate http://www.turbomeck.se/v-band-garrett-5
-Pro Turbo wastegate actuator (1.1bar spring)
-Custom made exhaust manifold with T3 flange (EGT and manifold backpressure connections also)
-3" RST exhaust with two straigh through mufflers and no CAT
-630cc siemens deka injectors swapped in tune (Now still 440cc injectors and mapping made for Td04hl-18T 7#)
-Custom intercooler on stock place
-Walbro 255lbs fuel pump in tank
-Hestec electronic boost control with 3 different boost settings
-MPE custom tune for Siemens EMS2000
-2.75" aluminium intake pipe from MAF to turbo
-Plx A/F wideband lambda
-B4204S intake and exhaust cam
-Phase 1 MAF
-K&N filter in stock filterbox
-STOCK Clutch, Pistons, Rods
-BSR boostgauge (52mm) -1 - 2.2 bar
-No dump valve or by-pass valve
-Stronger engine mounts
Most of the hardware buyed from www.Hevosvoima.com. Smile
18" Tsw Volcano rims and KW coilover suspension:
http://i119.photobucket.com/albums/o143/VulvaS40T4/Volvo2009v3netti.jpg
Manifold and turbo together:
http://i119.photobucket.com/albums/o143/VulvaS40T4/thesetti.jpg
Installation ready:
http://i119.photobucket.com/albums/o143/VulvaS40T4/imuputkijaturboasennettu.jpg
ThermoTec rapped 3" RST downpipe:
http://i119.photobucket.com/albums/o143/VulvaS40T4/downpipevalmis.jpg
Heat shield and 3" RST cat-back:
http://i119.photobucket.com/albums/o143/VulvaS40T4/putkistojalamposuoja.jpg
Cabin:
http://i119.photobucket.com/albums/o143/VulvaS40T4/etuosa2.j pg
Stock looking engine bay:
http://i119.photobucket.com/albums/o143/VulvaS40T4/konehuone 1.jpg
V-band internal wastegate:
http://i119.photobucket.com/albums/o143/VulvaS40T4/vpantapor tti.jpg
Walbro adapter for stock location (Works also with low fuel in tank)
http://i119.photobucket.com/albums/o143/VulvaS40T4/walbro255 sovite.jpg
Turbo Master Power 810023-063:
http://i119.photobucket.com/albums/o143/VulvaS40T4/masterpow ertiivistelmakuvia.jpg
Custom Exhaust manifold:
http://i119.photobucket.com/albums/o143/VulvaS40T4/pakosarja kuvia.jpg
Install pics:
http://i119.photobucket.com/albums/o143/VulvaS40T4/turbosivu stapakosarja2.jpg
http://i119.photobucket.com/albums/o143/VulvaS40T4/turbopaal tapakosarja1.jpg
Ported wastegate hole:
http://i119.photobucket.com/albums/o143/VulvaS40T4/hukkisset ti.jpg
Modified Oil return line:
http://i119.photobucket.com/albums/o143/VulvaS40T4/ljynpaluu .jpg
PLX gauge in cabin:
http://i119.photobucket.com/albums/o143/VulvaS40T4/plxmittar istossa.jpg
Wastegate actuator:
http://i119.photobucket.com/albums/o143/VulvaS40T4/proturbok ello.jpg
Custom intercooler:
http://i119.photobucket.com/albums/o143/VulvaS40T4/cooleriki inakenno001.jpg
Current setup compared to old setup:
TD04HL-18T compressor / turbine: 45mm / 46mm 0.49 A/R
Master Power compressor / turbine: 52.5mm / 54.6mm 0.63 A/R
http://i119.photobucket.com/albums/o143/VulvaS40T4/18tjamasteri.jpg
Video about Measuring manifold backpressure with 1.2bar boost and backpressure never rises above 1.2bar.
http://www.youtube.com/watch?v=do38zl7TKzg
Acceleration 1.2bar 3.gear:
http://s119.photobucket.com/albums/o143/VulvaS40T4/?action=v iew&current=MOV01244.flv
Turbon spool testing with different boost pressure. A/F ratio goes lean on high rpm with 18T software still on:
http://www.youtube.com/watch?v=rQGFaTld1vw
Other videos:
http://www.youtube.com/user/VulvaS40T4
  • Replies 502
I have to say you have done a really good job on the car.Youv got some low tires what type/size are they?Also about the muffler as to where did you get it and if you have a sound clip by any chance.Loving everything except the location of the gauges tho very innovative how can you keep checked both.
Thanks guys. Smile Tires are 215/35-18" Kumho KU31 on rear and semi-slick Hankook Z212 tires on front and same size. Rear muffler is normal 3" muffler compined with JT-tuning 3" oval shape tailpipe.
http://www.jt-tuning.se/shop/default.aspx?lng=ENG&cur=EU R
http://www.jt-tuning.se/shop/assets/prod_images/pJT76-9~2f14~2f27n.jpg
In the first post there is links to videos and you can hear the exhaust sound. In videos there was only one muffler and it was in my opinion too loud. After that added second muffler and sound is now good. I will make new videos after tune, probaply in April. Smile
Gauges are in that place because easy reading and not wanting to have too much boost and lean mixture before tune.
Couple more pics:
http://i119.photobucket.com/albums/o143/VulvaS40T4/Volvo2009.jpg
http://i119.photobucket.com/albums/o143/VulvaS40T4/Volvo2009v2.jpg
Tcode: Im planning of upgrading 850r flywheel and 850r stock clutch and pressure plate. That combo should hold 450-500nm which is enough for me. That would also bolt-on directly but what release bearing should i use, stock T4? What release bearing did you use with 707 pressure plate?
Heh heh. Laughing Planned on swapping this car to S60 T5 on summer 2009 but then did not found nice one and started tuning this one more. Smile Took about 1 month to make everything.
Phase 1 MAF because we are programming EMS2000 similar way as MTE does. Like Alpha-N style. Wink So phase 2 meter would not give much more but this is only plan. Let see what happens and does it work out okay.
Ordered Volvo 850R 1996 year single mass flywheel and clutch pack including pressure plate. It should hold +450nm and be as easy to use as stock clutch. Main point is to get rid of dual mass flywheel which is now making sound on idle. Also this setup is bolt on and if using 707 audi pressure plate i would have to modify flywheel. But this one is enough for me. Smile
