vulvas40t41568908561 Posted August 22, 2010 Author Report Share Posted August 22, 2010 tcode wrote on Sun, 22 August 2010 13:41Cams are grinded? In that case your hydro lifters now has increased travel, probably not good for high revs.Why do you have so retarded ignition (10 degrees only on 1.5 bar??), have you measured EGT? It's quite hot there I believe.. No not grinded, they are welded, so more stuff welded on them and base circle is still stock.Ignition is that low because it seems to make "knock" like sound in max torque rpm 5000rpm where there is 8 degree ignition. If i increase timing on there sound strongers. It very strange noise. On 6750rpm there is 10-11 degree ignition and no extra sounds. Could you send you ignition timing table to me? Just take a picture and uppit somewhere and place a link for me. Thanks.I have egt spot on manifold but no sensor yet. Planning of buing it. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted August 22, 2010 Report Share Posted August 22, 2010 Post your email address here or send me PM with it and I'll email you my ignition table. You'll be very surprised . Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted August 22, 2010 Author Report Share Posted August 22, 2010 tcode wrote on Sun, 22 August 2010 21:33Post your email address here or send me PM with it and I'll email you my ignition table. You'll be very surprised .PM send. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted August 25, 2010 Author Report Share Posted August 25, 2010 1.5bar and more ignition timing on upper revs and clutch started slipping on 100-200km/h pull when changing gear but it get grip then again. It might be possible that dualmassflywheel just bottoms up and thas why clutch slipping or 225tkm driven stock clutch has now too much torque. 100-150 km/h: 3,7 s100-110 km/h: 0,7 s 21 m100-120 km/h: 1,4 s 42 m100-130 km/h: 2,1 s 67 m100-140 km/h: 2,9 s 96 m100-150 km/h: 3,7 s 129 mPeak: 153 km/h100-200 km/h: 10,2 s100-110 km/h: 0,9 s 25 m100-120 km/h: 1,4 s 42 m100-130 km/h: 2,1 s 66 m100-140 km/h: 2,8 s 95 m100-150 km/h: 3,9 s 137 m100-160 km/h: 5,2 s 192 m100-170 km/h: 6,2 s 240 m100-180 km/h: 7,3 s 294 m100-190 km/h: 8,6 s 360 m100-200 km/h: 10,2 s 446 mPeak: 209 km/hMight be time to place that 850r clutch kit. Only question will it hold like that 500nm, would not like place 707 pressure plate on. So stock 850r clutch and pressure plate. Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted October 18, 2010 Author Report Share Posted October 18, 2010 Old setup is sold and goal 350hp was reached with 1.5bar boost with masterpower turbo. New setup and engine build has started.So I bought B4194T2 -00 engine from Sweden bone stock and driven 160tkm(100000miles). Engine was in great condition and prize was right. Also i bought JE pistons directly from JE USA (81.5mm bore) and Motornord H-profil rods. Camshafts from Autotech with 11.4mm lift in intake cam and 10.6mm in exhaust cam and 260degrees in both cams.From Torpis i bought stiffer valve springs and aluminum retainers so i can rev 9000rpm with this mechanical lifters top.Quaife differential lock was also bought so that both tires will spin. New turbo is Holset HX35 54/60mm 12# divided turbine with v-band downpipe. My friend is making new exhaust manifolt and new external wastegate is Tial MVS 38mm.New injectors are Bosch EV14 1000cc 3bar and enginemanagement is upgraded from Civinco SA500 to -> SA1000.Adjustable camgears where bought from Tommis Billett Finland and + - 15 degrees adjustment range in both sides. Double of original ones.Goal is to make strong engine which can handle 450hp power with estimated 2.0bar boost. Here is some pictures. Click to see.Engine: http://i119.photobucket.com/albums/o143/VulvaS40T4/b4194t2ko neruottista.jpgTurbo and cams: http://i119.photobucket.com/albums/o143/VulvaS40T4/hx35super nokat.jpgRods and wastegate: http://i119.photobucket.com/albums/o143/VulvaS40T4/porttijak angi.jpgInjectors: http://i119.photobucket.com/albums/o143/VulvaS40T4/2010-10-0 2145501.jpgExhaust manifolt not ready yet fully: http://i119.photobucket.com/albums/o143/VulvaS40T4/pakosarja porttijaputsari.jpgAdjustable cam gear: http://i119.photobucket.com/albums/o143/VulvaS40T4/tommisbil lett.jpgJE pistons: http://i87.photobucket.com/albums/k133/Sute_2006/15102010101 .jpgMore pictures and information to come. This setup is build in this winter and should be ready in spring 2011. Link to comment Share on other sites More sharing options...
wa666ou Posted October 18, 2010 Report Share Posted October 18, 2010 Hello!Nice setup.I'm going with the same turbo route.Still making research.1. So you are keeping ph1 head? Why don't you go w/ ph2 top?Are you planning or have you already done porting on the head?2. What's the price for piston + conrods?3. Camshafts price?4. What's the price for camgears? And how can one buy them?I'm still lurking around at X40nordic. There are some pretty good stuff on sale.Cheers!Risto Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted October 18, 2010 Author Report Share Posted October 18, 2010 wa666ou wrote on Mon, 18 October 2010 16:50Hello!Nice setup.I'm going with the same turbo route.Still making research.1. So you are keeping ph1 head? Why don't you go w/ ph2 top?Are you planning or have you already done porting on the head?2. What's the price for piston + conrods?3. Camshafts price?4. What's the price for camgears? And how can one buy them?I'm still lurking around at X40nordic. There are some pretty good stuff on sale.Cheers!Risto1. I bought phase 1.5 b4194t2 complete engine. My old engine is phase 1 b4194t. Only basic cleaning and reconditioning will be maid for this 1.5 head and no porting or bigger valves. Also this new engine will be fully reconditioned with original volvo parts. 2. Rods and pistons was about 1000euros but this was special prize.3. Cams are bought from mikkeki who bought them from autotech and prize was about 1200euros when new.4. 300euros is prize of these cam gears and they can ship also cam gears for you. Send email to them in english and ask volvo cam gears. http://www.tommisbillet.com/contacts/index.htmlAlso i will be using sachs 707 pressure plate with 850r clutch and flywheel. 100-200km/h best time with 18T mitsu was 13.0s(280hp) and with masterpower 10.0s(350hp) and now with holset goal is 8.0s(450hp).Lets see what happens... Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 18, 2010 Report Share Posted October 18, 2010 Hey dude glad to see you just keep evolving this thing rather than moving on, never looked at the cabin pics before until today, tell me you have a linear graph style gauge boost meter on the steering wheel, that thing is sick i've only seen those in old all-electric clusters on some old fords and chevys very unique bro, also take a look over at driftworks.com and see Andy Ps build, he doesn't really post much over here anymore, its gonna be a rwd s40, saab motor, cosworth jag gearbox, evo drivetrain, thing is rediculous Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 18, 2010 Report Share Posted October 18, 2010 vulvas40t4 wrote on Mon, 18 October 2010 15:571. I bought phase 1.5 b4194t2 complete engine. My old engine is phase 1 b4194t. Only basic cleaning and reconditioning will be maid for this 1.5 head and no porting or bigger valves. Also this new engine will be fully reconditioned with original volvo parts. 2. Rods and pistons was about 1000euros but this was special prize.3. Cams are bought from mikkeki who bought them from autotech and prize was about 1200euros when new.4. 300euros is prize of these cam gears and they can ship also cam gears for you. Send email to them in english and ask volvo cam gears. http://www.tommisbillet.com/contacts/index.htmlAlso i will be using sachs 707 pressure plate with 850r clutch and flywheel. 100-200km/h best time with 18T mitsu was 13.0s(280hp) and with masterpower 10.0s(350hp) and now with holset goal is 8.0s(450hp).Lets see what happens...With all respect, if your goal is "just" 450HP, you are wasting a lots of money. I'm over 450HP with stock engine (but I'll rebuild it with forged internals just to be safe for a longer period), cheap n/a cams, no special cam gears, no special valve lifter springs (actually I'm reving 8k with hydro lifters on a daily biasis over a year or more, no problem). And, at the end, my car pulls 100-200 km/h in less than 8 seconds (GPS), 12,76 sec at 1/4 mile etc.http://www.youtube.com/watch?v=jl4URM2rA6gHowever, if you build your engine that way, you'll have an excellent base for another 100 or 200 HP with a larger turbo, but in reality, do you really need 600HP on a fwd car ? Link to comment Share on other sites More sharing options...
wa666ou Posted October 18, 2010 Report Share Posted October 18, 2010 tcode, 450hp with stock rods, too?VEMS must be working wonders Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 18, 2010 Report Share Posted October 18, 2010 wa666ou wrote on Mon, 18 October 2010 21:53tcode, 450hp with stock rods, too?VEMS must be working wonders Yes, everything is stock except n/a cams. Boosting 2+ bar from 5 to 8k rpm. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 19, 2010 Report Share Posted October 19, 2010 Tcode are you running the cams from a stock normally aspirated x40? Link to comment Share on other sites More sharing options...
theForgottenone Posted October 19, 2010 Report Share Posted October 19, 2010 How much for the turbo shield? Any extra left? Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted October 19, 2010 Author Report Share Posted October 19, 2010 xcites: no extra turboshield left. Its custom made.Tcode: Yes i know you have +400hp with stock engine but my point was now to do engine which can in future handle more power if still wanted. Similar setup can handle like you sayd 600hp with only turbo swap and couple other things.So now extra safe with forged parts and low power. Also this hx35 turbo is good for daily driven car because it will spool fully in 4000-4500rpm which is okay and similar like gt3071. When going in 500-600hp range hx40super is the choice and spool whould be about 1000rpm later about 5500rpm which is little bit too slow for my taste in this point.So now tiny turbo only. Link to comment Share on other sites More sharing options...
arrtchiu Posted October 19, 2010 Report Share Posted October 19, 2010 Ol' Dirty Noodle wrote on Tue, 19 October 2010 11:14Tcode are you running the cams from a stock normally aspirated x40?According to his build thread he's using just intake cam, but he might've changed again Quote:So now extra safe with forged parts and low power. Also this hx35 turbo is good for daily driven car because it will spool fully in 4000-4500rpm which is okay and similar like gt3071. When going in 500-600hp range hx40super is the choice and spool whould be about 1000rpm later about 5500rpm which is little bit too slow for my taste in this point.I agree, sute's setup is great but it spools way too late for my liking.What made you choose hx35? I ask as I'm currently debating turbo choice myself Edit: What about hx40 with smaller turbine housing? Link to comment Share on other sites More sharing options...
