vulvas40t41568908561 Posted October 19, 2010 Author Report Share Posted October 19, 2010 arrtchiu wrote on Tue, 19 October 2010 08:05What made you choose hx35? I ask as I'm currently debating turbo choice myself Edit: What about hx40 with smaller turbine housing?Tcode has N/A intake cam and stock T4 exhaust cam.Hx35 is fast spooling and great for maximum 500hp and also prize is cheap about 700euros. Comperssor size is the main point with turbine a/r what effects spool so hx40 is late spooling even with small turbine. Also small turbines are not good for high rpm n/a like power with flat torque and nice power. So i dont like to mix small turbines with big compressors.So Hx35 was best match for me. Here is compressor chart for my hx35super turbo and my turbo is with bigger turbine side than in this picture 8#->12# and exhaust side is also bigger 55mm->60mm. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 19, 2010 Report Share Posted October 19, 2010 Ol' Dirty Noodle wrote on Tue, 19 October 2010 05:14Tcode are you running the cams from a stock normally aspirated x40?I'm running both cams from a stock naturally aspirated x40. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 19, 2010 Report Share Posted October 19, 2010 vulvas40t4 wrote on Tue, 19 October 2010 07:28Hx35 is fast spooling and great for maximum 500hp and also prize is cheap about 700euros. Comperssor size is the main point with turbine a/r what effects spool so hx40 is late spooling even with small turbine. Also small turbines are not good for high rpm n/a like power with flat torque and nice power. So i dont like to mix small turbines with big compressors.So Hx35 was best match for me. I'm having 0,1b@1800, 0,7b@3500 1,7@3700 2b@38xx rpm, and personally I doubt you will ever see those figures with HX35 turbo. But yes, it's cheap compared to the GT30 . Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted October 19, 2010 Author Report Share Posted October 19, 2010 tcode wrote on Tue, 19 October 2010 09:55vulvas40t4 wrote on Tue, 19 October 2010 07:28Hx35 is fast spooling and great for maximum 500hp and also prize is cheap about 700euros. Comperssor size is the main point with turbine a/r what effects spool so hx40 is late spooling even with small turbine. Also small turbines are not good for high rpm n/a like power with flat torque and nice power. So i dont like to mix small turbines with big compressors.So Hx35 was best match for me. I'm having 0,1b@1800, 0,7b@3500 1,7@3700 2b@38xx rpm, and personally I doubt you will ever see those figures with HX35 turbo. But yes, it's cheap compared to the GT30 . Yes 2.0bar should be about 4500rpm with hx35. Hx35 is also bigger turbo than gt3071. Compare compressor maps. About 10lbs more juice in hx35 than gt3071... Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 19, 2010 Report Share Posted October 19, 2010 vulvas40t4 wrote on Tue, 19 October 2010 09:48tcode wrote on Tue, 19 October 2010 09:55vulvas40t4 wrote on Tue, 19 October 2010 07:28Hx35 is fast spooling and great for maximum 500hp and also prize is cheap about 700euros. Comperssor size is the main point with turbine a/r what effects spool so hx40 is late spooling even with small turbine. Also small turbines are not good for high rpm n/a like power with flat torque and nice power. So i dont like to mix small turbines with big compressors.So Hx35 was best match for me. I'm having 0,1b@1800, 0,7b@3500 1,7@3700 2b@38xx rpm, and personally I doubt you will ever see those figures with HX35 turbo. But yes, it's cheap compared to the GT30 . Yes 2.0bar should be about 4500rpm with hx35. Hx35 is also bigger turbo than gt3071. Compare compressor maps. About 10lbs more juice in hx35 than gt3071...HX35 will flow more air, no doubt. But you'll sacrifice almost 1000 rpm in a midrange, meaning your car won't be very nice as a daily driver. Also, my car spinning both wheels at 200 km/h at the wet road. What will your do with 100+ HP more, flying ? Link to comment Share on other sites More sharing options...
vulvas40t41568908561 Posted October 19, 2010 Author Report Share Posted October 19, 2010 tcode wrote on Tue, 19 October 2010 10:55HX35 will flow more air, no doubt. But you'll sacrifice almost 1000 rpm in a midrange, meaning your car won't be very nice as a daily driver. Also, my car spinning both wheels at 200 km/h at the wet road. What will your do with 100+ HP more, flying ? True under 4000rpm gt3071 would be better choice. But i wanted to have turbo which has still more potential if needed. Every turbo is compromise. Also normal driving is still okay even with N/A power and i have no need to accelerate with 5.gear in slow speeds. I think that hx35 is best compromise for me. Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 19, 2010 Report Share Posted October 19, 2010 It's ok if you can live with it. I know that I wouldn't .Anyway, good luck with your new setup! Looking forward to see the figures . Link to comment Share on other sites More sharing options...
Sute1568908560 Posted October 19, 2010 Report Share Posted October 19, 2010 Guys..you have forgotten some basic principles regarding small Volvo engine:Big turbo, huge lag = lots of powerSmall turbo, less lag = less power Link to comment Share on other sites More sharing options...
arrtchiu Posted October 19, 2010 Report Share Posted October 19, 2010 Sute wrote on Tue, 19 October 2010 19:48Guys..you have forgotten some basic principles regarding small Volvo engine:Big turbo, huge lag = lots of powerSmall turbo, less lag = less power No doubt about that!Though some of us prefer to have big power by 6000, not spool Link to comment Share on other sites More sharing options...
wa666ou Posted October 19, 2010 Report Share Posted October 19, 2010 I've heard that HX35 super on 2 litre engine is capable of making 1bar @3500 rpm.That's what our stock 14T does Link to comment Share on other sites More sharing options...
tcode1568908558 Posted October 19, 2010 Report Share Posted October 19, 2010 wa666ou wrote on Tue, 19 October 2010 14:00I've heard that HX35 super on 2 litre engine is capable of making 1bar @3500 rpm. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted October 19, 2010 Report Share Posted October 19, 2010 wa666ou wrote on Tue, 19 October 2010 08:00I've heard that HX35 super on 2 litre engine is capable of making 1bar @3500 rpm.That's what our stock 14T does Probably with #8 housing and driving on uphill on 5th gear.. Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 19, 2010 Report Share Posted October 19, 2010 I'm moving to Europe for the cars Link to comment Share on other sites More sharing options...
arrtchiu Posted October 20, 2010 Report Share Posted October 20, 2010 I just jumped in a time machine and found VulvaS40T4's car at some point in the future! Video one (600hp?)vsVideo two (450hp?)Looks pretty close to me Link to comment Share on other sites More sharing options...
Ol' Dirty Noodle Posted October 20, 2010 Report Share Posted October 20, 2010 Daaaamn you see the tac needle slam through the redline??? sadly I don't think my 19t will ever do that....however way down the road when the 40s strictly a toy, SR20DET swap, massive gutting, RWD FTW (2 years hopefully) Link to comment Share on other sites More sharing options...
