Sute1568908560 Posted May 2, 2014 Author Report Share Posted May 2, 2014 Some new stuff under the hood. Garret GTX4202R and Tial 50mm dump valve.. Link to comment Share on other sites More sharing options...
Slevin Posted May 2, 2014 Report Share Posted May 2, 2014 When does it start to build boost? Link to comment Share on other sites More sharing options...
theForgottenone Posted May 3, 2014 Report Share Posted May 3, 2014 It is getting ridiculous when the turbo is bigger than the engine , lol Link to comment Share on other sites More sharing options...
Sute1568908560 Posted May 3, 2014 Author Report Share Posted May 3, 2014 When does it start to build boost? I think around 5000 rpm we're seeing some positive signs. 5600-5700 rpms is perhaps the threshold for efficient boost. Rather good for this size of an engine, higher static compression (10:2) is of a help in my case.. Link to comment Share on other sites More sharing options...
Slevin Posted May 3, 2014 Report Share Posted May 3, 2014 Rpm limit?10k? Link to comment Share on other sites More sharing options...
Sute1568908560 Posted May 4, 2014 Author Report Share Posted May 4, 2014 Yup, something like that. Efficient power band is probably from 6000 - 9500... Had a quick test yesterday and it is pulling really well. Gotta take some film later on. Dyno withni 2-3 weeks. Link to comment Share on other sites More sharing options...
wa666ou Posted May 9, 2014 Report Share Posted May 9, 2014 This bad boy looks ridiculous.What's your goal with this build?Looks like you are getting near to four digit numbers on dyno... Link to comment Share on other sites More sharing options...
Sute1568908560 Posted May 10, 2014 Author Report Share Posted May 10, 2014 This bad boy looks ridiculous.What's your goal with this build?Looks like you are getting near to four digit numbers on dyno...Looking for 800 hp for this summer. More later on. Turbo is capable for 1100. Link to comment Share on other sites More sharing options...
PoLonY Posted May 28, 2014 Report Share Posted May 28, 2014 holy crap this is awesome Link to comment Share on other sites More sharing options...
wa666ou Posted June 5, 2014 Report Share Posted June 5, 2014 Sute, you have very high powered S40 now. Are you still running stock M56 gearbox and Quaife LSD?How is it holding on?And have you had any issues with driveshafts?There's this guy in Estonia who's building C70 and he's also using M56 and Gripper LSD. That LSD has broken now. Then he used stock differential and the same story.See images here: http://foorum.volvoc...=28265&start=75Use Google translate to understand text. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted June 8, 2014 Author Report Share Posted June 8, 2014 I´ve got M56L or L2 with Quaife. Never had any problems with those, they seem to be only durable thing in this combo. Maybe that guy have some sort of misalignment or something. M56 has been driven with 1000 horses without problems. Flywheel is the first thing to worry especially if there is grip available. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted July 4, 2014 Author Report Share Posted July 4, 2014 I was driving in 1 mile event a few weeks ago. Managed to destroy compressor wheel a bit on the first test run, but despite that and low 1,8 - 1,9 bar boost, the final speed was 293 kph. The purpose was to raise the boost to 2,5bar on the second run, but luckily the boost pipe blew off and I did not destroy turbo any more.Hear the whining sound when sifting to 4th gear: Link to comment Share on other sites More sharing options...
wa666ou Posted July 5, 2014 Report Share Posted July 5, 2014 So what exactly got destroyed?What could be the cause for that? Link to comment Share on other sites More sharing options...
Sute1568908560 Posted July 5, 2014 Author Report Share Posted July 5, 2014 Some object entered into compressor causing bent compressor wings. I suspect it was a part of air filter or some plastic thing since there was melted plastic type stuff in intercooler.Turbo will be repaired soon and the engine will be torne down since there is too much blow by past the pistons causing high crankcase pressure.In that pull the engine spit out almost half a litre of oil and app desilitre of ethanol. Hopefully back on track on September 1 mile event. Link to comment Share on other sites More sharing options...
Sute1568908560 Posted August 10, 2014 Author Report Share Posted August 10, 2014 A bit driving for a while. Did few quarter mile runs, resulting 205,5 and 205,4 kph for trap speeds. "Track" was an old airfield whit shitty and slippery tarmac. Rather good trap speed though in that respect . As regars the ET, nothing special really to tell. Maybe on next weekend on a better surface ending up with better ET times. Link to comment Share on other sites More sharing options...
