Guest fluidgroove Posted February 9, 2011 Report Posted February 9, 2011 wth happened to this site?!?also can someone fix my acccount....password not working Quote
theForgottenone Posted February 10, 2011 Report Posted February 10, 2011 wth happened to this site?!?also can someone fix my acccount....password not workingI sent you an email through this forum for Che email so your password can get reset. If that email is invalid, then it wont' get to you. Warren Quote
arrtchiu Posted March 5, 2011 Report Posted March 5, 2011 Forum activity seems to have really died down since the change, maybe you could set reply notifications to be on by default?That was what we had before and I'd say was probably a major contributor to people coming back to the site.Re: IE9 compatibility, you can add a HTTP header to your responses to tell it to go to IE6/7/8 compatibility mode. Might be worth it as a short term solution Quote
theForgottenone Posted March 5, 2011 Report Posted March 5, 2011 Forum activity seems to have really died down since the change, maybe you could set reply notifications to be on by default?That was what we had before and I'd say was probably a major contributor to people coming back to the site.It only take a few seconds to set it up. If members want to be active on this forum, a couple click shouldn't be too hard. 1 Quote
sdirkx Posted June 1, 2011 Report Posted June 1, 2011 (edited) Big project We will start a topic in the showroom and list them and pin it. Again been busy.I cannot find the Big projects anymore. They disappeared?edit: Found it! http://www.30forty50.com/forum/forum/29-member-announcements/ Edited June 1, 2011 by sdirkx Quote
Dr Brutal Posted June 2, 2011 Report Posted June 2, 2011 IMO it should be categorized like it was back in the day. How-to's should definitely have their own section. Quote
Guest arrtchiu Posted June 7, 2011 Report Posted June 7, 2011 Any chance you could turn on SSL? Even with a self-signed cert... just so your average tcpdump'er can't get a password/session at least.Oh, speaking of which - am I correct in guessing the iOS app doesn't use SSL at all either? Quote
Che'_Moderator Posted June 8, 2011 Author Report Posted June 8, 2011 Any chance you could turn on SSL? Even with a self-signed cert... just so your average tcpdump'er can't get a password/session at least.Oh, speaking of which - am I correct in guessing the iOS app doesn't use SSL at all either?SSL really doesnt do much unless I keep everything on a different server. I have extra IPs for SSL and at one point used them for log in but really added nothing other than a couple hundred dollars a year cost and some lag. Quote
Guest arrtchiu Posted June 13, 2011 Report Posted June 13, 2011 SSL really doesnt do much unless I keep everything on a different server. I have extra IPs for SSL and at one point used them for log in but really added nothing other than a couple hundred dollars a year cost and some lag.When the network is being shared with 5000+ other programmers, I don't like to take any chances. Quote
daveherz827 Posted July 18, 2011 Report Posted July 18, 2011 Limitation of php. Thats why I installed the google search option. Click the drop down and select google site searchWow that saves a lot of trouble... glad I finally found this. Also, I'm not sure if this is where I would post this. If its relatively simple, you guys should add a random thread button I always come on here to find new stuff, and that would make it way easier hahaha anyway thanks! Quote
