gdizzle Posted May 17, 2006 Report Share Posted May 17, 2006 MBC install thanks to Javadoc.http://volvospeed.com/vs_forum/index.php?s...ndpost&p=511683 Link to comment Share on other sites More sharing options...
the underlørd Posted August 11, 2006 Report Share Posted August 11, 2006 Help on installing a boost gauge. Link to comment Share on other sites More sharing options...
JESSEXC Posted March 15, 2007 Author Report Share Posted March 15, 2007 Can I add a Turbo to my 850 NA? Link to comment Share on other sites More sharing options...
gdizzle Posted May 2, 2007 Report Share Posted May 2, 2007 Engine Rebuild InfoDiscussion on parts needed, OEM vs. Elring, etc (Info inludes: gaskets, Rods, Bearings[main/rods], pistons)"china" Rods, An evaluationMahle piston ring thicknessProper engine break in procedure Link to comment Share on other sites More sharing options...
gdizzle Posted May 14, 2007 Report Share Posted May 14, 2007 motronic 4.3/4.4 ecu pin mapThanks Mark! Link to comment Share on other sites More sharing options...
gdizzle Posted May 24, 2007 Report Share Posted May 24, 2007 A/C removal, thanks Johann.http://volvospeed.com/vs_forum/index.php?s...c=48765&hl=QUAIFE LSD INSTALLThanks Johannhttp://volvospeed.com/vs_forum/index.php?showtopic=64440 Link to comment Share on other sites More sharing options...
gdizzle Posted December 20, 2007 Report Share Posted December 20, 2007 ARP recommends using the STRETCH METHOD for torquing bolts. Follow instructions for using a stretch gauge. Stretch bolts to .0056"-.0060". If you do not have a stretch gauge, follow these steps using the ARP Moly Assembly Lube. After rods are installed into the motor, torque bolts to 47ftlbs. Loosen the bolts. Torque to 47ftlbs again. Loosen the bolts and torque to 47ftlbs a third and final time. A log should be kept on the original non-torqued length of each bolt. Bolts that have any permanent deformation or have increased in non-torqued length should be replaced.please note part number in quote header. Link to comment Share on other sites More sharing options...
flyfishing3 Posted January 9, 2009 Report Share Posted January 9, 2009 wasn't sure where else to put this.7.3S70, V70, C70, 850* Cross Country** Paint codes 930-935 are for aluminium rims.*** For railsTouch-up paintCode Touch-up-pen400 ml 150 ml 18 ml19 Stone black 1396 634-6 9437 156-4 1396 573-6130 Silver met. – 9437 177-0 9434 525-31771) Silver grey met. – 9437 200-0 9434 531-1189 Polar white 9437 207-5 9437 208-3 9437 209-1214 Dark grey met. – 9437 223-2 9434 535-2406 Medium blue met. – 9437 265-3 9434 541-0411 Platina beige met. – 9437 270-3 9434 544-4412 Tropic green met. – 9437 271-1 9434 545-1414 Rubin red met. – 9437 272-9 9434 546-9415 Fiord blue met. – 9437 273-7 9434 547-7416 Onyx green met. – 9437 274-5 9434 548-5417 Nautic blue pearl – 9437 275-2 9434 549-3418 Regent red met. – 9437 276-0 9434 550-1419 Silver sand met. – 9437 277-8 9434 503-0420 Aubergine met. – 9437 278-6 9434 507-1421 Dark olive pearl – 9437 279-4 9434 511-3422 Turquoise met. – 9437 280-2 9434 627-7423 Brick orange met. – 9437 281-0 9434 631-9424 Polar white met. – 9437 282-8 9434 635-0425 Champagne met. – 9437 283-6 9434 655-8426 Silver met. – 9437 284-4 9434 675-6427 Dark grey pearl – 9437 285-1 9434 679-8428 Garnet red pearl – 9437 286-9 9434 683-0431 Aqua pearl – 9437 289-3 9434 687-1434 Frost green met. – 9437 291-9 9437 109-3435 Saffron met. – 9437 292-7 9437 113-5436 Cassis pearl – 9437 293-5 9437 117-6437 Sandstone pearl – 9437 294-3 9437 121-8440 Linear pearl – 9437 305-7 9437 306-5441 Laser blue met. – 9437 308-1 9437 309-9443 Moondust met. – 9437 314-9 9437 315-6445 Venetian pearl – 9437 328-9 9437 329-7601 Classic red 1396 748-4 9437 297-6 1396 751-8604 Midnight blue 1396 772-2 9437 235-6 1396 768-2606 Classic green 1399 226-8 9437 301-6 1399 229-2607 Creme yellow – 9437 302-4 9434 520-4609 Bright red – 9437 303-2 9434 667-3930 Silver* met. – 9437 330-5 –931 Dark silver* met. – 9437 331-3 –932 Anthracite* met. – 9437 332-1 –933 Champagne* met. – 9437 333-9 –934 Soft silver* – 9437 334-7 –935 White silver* met. – 9437 335-4 –Grey2) met. 9434 691-3Beige primer 9437 350-3 – 9437 351-1 Link to comment Share on other sites More sharing options...
'93 Dave Posted February 12, 2010 Report Share Posted February 12, 2010 good cam reference http://volvospeed.com/vs_forum/index.php/topic/128714-na-cams/page__view__findpost__p__1728135 Link to comment Share on other sites More sharing options...
