Welditup Posted April 19, 2017 Report Share Posted April 19, 2017 I plugged in my scan tool today and was surprised how many codes I got. I have a total of 18 codes with some of them repeated more than once. Any tips or suggestions before I start wrenching on it this weekend? I want to take the right approach to this and some help would be very much appreciated. I'm going to start with checking my wires for any mix up but everything was pretty much fool proof. I had everything marked and numbered and the only thing I had to wire up was the o2 sensors. All the other connections had harnesses so it just clicked together. p0303- #3 misfire p0015- exhaust cam shaft over retarded p0351- ignition coil a primary secondary circuit p0234- turbo charger overboost condition p0236- turbo charger boost sensor A circuit p0108- manifold absolute pressure bar sensor high input p0102- mass or volume air flow low input p0505- idle air control system p0014- exhaust camshaft position timing over retarded bank 1 p0303- cylinder 3 misfire detected p0351- ignition coil a primary secondary circuit p0234- turbo overboost condition p0236- turbo overboost sensor A circuit p0108- manifold absolute pressure high sensor high input p0102- mass or volume air fow circuit low input p0505- idle air control system p0014- exhaust camshaft position over advanced Link to comment Share on other sites More sharing options...
