12C70 Posted February 3, 2020 Report Posted February 3, 2020 Hello all, Could maybe use a bit of advice here... googling has not yielded the best results. I have a 2012 C70 displaying the convertible top service required message.. and of course, when driving, I am getting the annoying constant chime and the message to stop driving because the top might be damaged. I *think* I might have traced the issue down to the hydraulic pump motor.. I put power to it and the pump motor lazily spins then pops the fuse in my power probe. I reached out to Klaus at TopHydraulics and he kindly informed me that the motor should have no more than a 30 amp draw (going to test this soon). Also, the hydraulic reservoir is full of fluid and nothing seems to be leaking, but I need to find folks to help me lift the top to inspect the hydraulic cylinders... not an easy feat in rural Colorado's winter :) All that being said, is there anyway for the time being while I perform diagnostics that I can disable this chime so that the car is still usable? I made 110% sure that the top is locked down. Any suggestions?
Ihatespeedbumps Posted February 10, 2020 Report Posted February 10, 2020 I'm not aware of any way to defeat the chime unless the car thinks the top is fully open/closed. Do you have VIDA to try and erase any codes that are stored?
