To_Masz Posted June 21, 2020 Report Share Posted June 21, 2020 Hello sorry in advance for my english but i use google translator.. I have changed the engine to 2.3T5 from C70 1999 ME7 in my S70. The engine and ECU come from the version with automatic transmission. Since then, the engine does not want to exceed 4k rev. I bought a second ECU from the version with manual transmission but the problem did not disappear. I changed the rev counter, ECU and do I need anything else to change? Where is the problem? I also have a C70 2.4 with a manual gearbox and the revs there exceed 4k Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted June 22, 2020 Report Share Posted June 22, 2020 Was the swapped car originally an automatic? If so you need a custom tune for the manual swap. Link to comment Share on other sites More sharing options...
To_Masz Posted June 22, 2020 Author Report Share Posted June 22, 2020 7 hours ago, Ihatespeedbumps said: Czy zamieniony samochód był pierwotnie automatyczny? Jeśli tak, potrzebujesz niestandardowej melodii do ręcznej zamiany. No car ECU yes. Car is manual factory. Swaped ECU is automatic Today I found the reason for the turnover limit. ECU proved to be guilty. I exchanged ECU with C70 2.4 with a manual transmission and the engine exceeded 4k. It looks like the current ECU is not from a manual gearbox. I came to this conclusion after changing this ECU to C70 2.4 and here also had a 4k rev Link to comment Share on other sites More sharing options...
