P80 p2 parts etm turbo downpipe turbine housing injectors
Bought an 04 c70 b5234t9 to swap
Have
Fuel rail with blues $30
ETM with intake manifold $80
Auto flex plate $30
P80
Sas pump $50
850 x70 air box $50
Exhaust manifold $20
New obx straight flange downpipe $200
Straight flange housing $55 (no cracks)
Stock straight flange downpipe with cat $100
Used td04hl-16t p80 feed ports, little to no shaft play $100
Low mileage (60k) td04hl-16t p2 style feed , no shaft play $200
Snail turbo cnc billet wastegate actuator fits straight and angle flange with 1 bar spring brand new valued $140 will sell $80..
Snail turbo - Td04hl-22t billet 6+6 (td05-18g) wheel extended tip 50mmx71mm with 9 blade turbine. Silicone hd cbv with medium spring 14-18psi
Has 4 open coolant port with plugs
Paid $960 was dropped by a friend and seems have some rubbing when spun by hand. Never installed so essentially new Will sell for $400 fp offers rebuild for $275. My loss is your gain. Good for around 320-360whp depending on boost and fuel.. Possible it's fine but had 2 so went with the other...
