thegary Posted August 11, 2020 Report Posted August 11, 2020 Hey everyone, Perhaps you can give me some help. Have a 2011 Volvo C30 RDESIGN 6spd. I have a vibration, and wobble, and clicking on stop starts or turning. When i turn its just one click , nothing continuous. At speeds over 90kph, I get a wobble from the front left. Also under acceleration it feels like the something isn't correct in the front left. I would describe it as vibration or engine missing. I have replaced both axles as i had a tear in the right boot, so replace both sides. I have put IPD stabilizer end links on . Checked balance of front left wheel as well. Sometime when I am braking from speeds of 90kph plus, i get vibration through wheel, like a warped rotor. But other times its fine. Doesn't happen at lower speeds at all. Car idles great, smooth, great gas mileage, no knocks for contact sounds from engine bay. At a loss on what next. Could strut mount bushings and bearings be creating this issue? Anything suggestions that would help , would be most appreciated. Thank you Gary
TF850R Posted August 11, 2020 Report Posted August 11, 2020 How many miles on the car or original suspension?
thegary Posted August 11, 2020 Author Report Posted August 11, 2020 9 minutes ago, Tonyfr said: How many miles on the car or original suspension? @Tonyfr I have 129000 km;s on the car - 80156 miles Gary
TF850R Posted August 11, 2020 Report Posted August 11, 2020 I would replace the strut mounts and bearings (struts too if you go that far). Have you checked the control arms and ball joints? On a side note, my Porsche Carrera had a clicking noise on one side when I would take off from a standstill. Turns out the strut was loose internally and the shaft was moving.
