2015 XC60 T6: R-DesignOEM Hitch and eTrailer wiring
Applefritter
Adding photos is moving quite slowly, but this gives an idea.
Main motive in using OEM was keeping the hitch high, even though I knew it would require at least some cutting of the bumper. Had to cut more than I thought, but it could have been worse. Not the best work in the world, but not the worst I’ve seen, and i sort of made it up as I didn’t have a template like the dealerships use. If you buy the OEM hitch new, it may come with a template (bought mine used)
OEM wiring seemed steep in price compared to eTrailer/other options. Bought the “Tekonsha” harness and powered it from the existing “trailer lights” option in the rear fuse box. Not a professional job by any stretch, but it works.
Removing rear bumper isn’t too bad. 5 screws in each wheel well. 4 bolts under the bumper. Feels odd pulling it off (as though you are breaking it), but didn’t really have any problems. Disconnect the rear fog lights (and don’t do what I did and forget to connect them before putting the bumper back on).
Hope this helps!
