galexie64 Posted April 5, 2021 Report Share Posted April 5, 2021 I'm trying to modify the bin to set the tune for green injectors. 607_rev5b.bin with rev5b_607-608_fox _01.xdf When I try to update the table "Injector Opening Time by Voltage" and save, it closes the table and goes right back to the blue injector table not saving any of my changes. What am I doing wrong? Link to comment Share on other sites More sharing options...
Midnight Caller Posted April 5, 2021 Report Share Posted April 5, 2021 54 minutes ago, galexie64 said: Hello ! Is that the only table that gives you problems ? Can you succesfully edit other tables and save them ? Maybe there is a problem with the decimal separator (use "," instead of "." or the other way around)? Link to comment Share on other sites More sharing options...
gdog Posted April 5, 2021 Report Share Posted April 5, 2021 Also make sure you are running TP in Administrator mode. Link to comment Share on other sites More sharing options...
galexie64 Posted April 5, 2021 Author Report Share Posted April 5, 2021 1 hour ago, Midnight Caller said: Hello ! Is that the only table that gives you problems ? Can you succesfully edit other tables and save them ? Maybe there is a problem with the decimal separator (use "," instead of "." or the other way around)? It seems to only be a problem in this table. Link to comment Share on other sites More sharing options...
