Yellow95 Posted June 16, 2021 Report Share Posted June 16, 2021 The fancy step motor boost gauge that i bought needs an uninterrupted switched power source to function properly. All the usual suspects are cut during ignition. Does anyone know where I could find one? Please let me know if you know. Gary Link to comment Share on other sites More sharing options...
apeacock Posted June 17, 2021 Report Share Posted June 17, 2021 I believe the big red wire to the accessory connector is on all the time. You could run a new line from the battery and install a fused switch so it only comes on after you've started the car. Back in the day I used a sunroof switch as a momentary switch for an air horn. Same could work for an additional fog light switch in the bank behind the wheel. Link to comment Share on other sites More sharing options...
gdog Posted June 19, 2021 Report Share Posted June 19, 2021 The 850 has an accessory connector under the driver side dash; not sure if the S70 does? Look around under the driver's side dash until you find the Grn wire w/Ylw tracer. Test it with test light or volt meter but it should be hot in RUN and START key positions. http://volvospeed.com/vs_forum/topic/173823-wideband-power-connecting/?do=findComment&comment=2427914 Link to comment Share on other sites More sharing options...
