No low beams at all unless key is in position 2
CoffeeBean
Hello, my 2000 Volvo S70 low beams have decided they no longer want to illuminate, I replaced them last year with LED's and had no problems at all with them, until tonight when they decided to hyper flash and not work at all.
I was forced to pull the high beam stock all the way home, when I got home I checked out the fuses and none were blown as far as I could tell with my multimeter, I also checked the battery just in case and it had 12.6 volts.
I didn't go further because can't see anything under the hood due to it being 3 in the morning, yet I noticed the illuminate feature when you turn off the car and pull the highbeam stock, it would just click a relay repeatedly and not keep the low beams on, yet when the key is in position 2, the low beams and high beams all work perfect.
Any help would be greatly appreciated!
I will also add a couple things I forgot,
I installed new high beams aswell and had the burnt bulb warning start flashing on the dash but never had any problems or flashing of the physical lights, both high and low beam
My car is a Canadian model so I cannot touch the DRL screw due to laws and regulations, so my low beams are on all the time
Touch the DRL screw.
Have you tried changing back to halogen bulbs to see if that cures the issue?   Perhaps you got low quality LED's?
I got the Sylvania h7 led as my main headlights, I'll see if putting the old high beam bulbs back in works
Also can't touch the DRL screw since it's capped due to it being a Canadian model
Edit: the lights just started working again this morning, in all 3 modes (walking lights, position 2 and when the car has started) I'll see if they work tonight and if they do, I won't turn on my high beams, as I have a feeling that is the main culprit
So the problem came back last night again, I have now switched the regular bulbs back to halogens and completely unplugged the high beams, on the second startup, the lights just suddenly started working again, I'll see tonight if it happens again, because there is a loud relay clicking that sounds like it's coming from behind the dash board
  • 2 weeks later...
Any update on this?
Have you also checked to see if you have any wire damage?
I'm not fully familiar with the 99-00 wiring, but on my wife's '97 850 GLT she just had the same issue. No lights and only hi-beams if she held the stalk "ON". Fuse was good.
She was travelling and over an hour away, so I dug into the wiring diagrams quick. The only other relay in the system besides the main light relay is the "+15-supply Overload Relay". (It's a "J" relay (#106) on the 96-97 850s) I had her access both of those and give each a good "tap". After that she had headlights.
When she gets home tomorrow, I'm going to investigate both of those relays as replace as needed, as one of them is failing.
