Electronic Throttle Bodys (Etm, Eth..Etc) Updated 9/09!
Bay13
if you call having your car off the road for a couple of days 'free' then... yeah. i personally wouldn't screw with a 1 grand ECU investment without guarentees. if the ETM software overwrites the IPD software, does the IPD software then overwite the ETM software? i'm waiting for them to figure it out.
Exactly. I would be suspiscious of this myself. If the ETM code is seperate from the ignition/fuel portion, it shouldn't matter. So the fact that the ETM flash jacks the MTE flash, tells me that the MTE reflash will just overwrite the ETM code you just had done!
  • Replies 127
So thats what the IPD Upgrade does...rewrite the ETM programs?
This is good info...I have been considering getting an IPD, but have been back and fourth on it...still have not made a definate decision, as the Civinco is now available, and i hear different hings about differnet systems, etc.
It will be a bit until I do an ECU upgrade, so I have a little time.
I just got my 2000 C70 back from the dealer.....In for some maintanence, while there they did the ETM software update.
My UPsolute chip was wiped out....driving home i was at stock boost
I forgot how slow the car was.
wow..that is the suck!
have you contaced Upsolute about that?
would they honor stuff like that, or do you have to shell out full amount for a re-program?
I have an upsolute chip and was told by upsolute dealer here in Charlotte, NC that they would rewrite the chip for free if it got wiped by a Volvo repair/upgrade.
I have not had to take them up on it yet. I also have not had the ETM upgrade done (not even sure if if it applies to an R)
Volvos built from the year 1999 and after have an ETM. The update should apply to all you with an ETM (I.E. a car built in 99 or after). Always good to double check with the deal.
i have a 99 s70 n/a ... does the etm upgrade apply to this car as well? if so im going to get it done immediately
you should be covered.
yup, I am gonna swing into the stealership during lunch hour today... maybe they can do it while I get some Qdoba. How long did it take them to do it for you guys?
